How Do You Solve the Laplace Equation in a Semi-Infinite Strip?
  • Thread starter Thread starter Benny
    Pde
The discussion focuses on solving the two-dimensional Laplace equation in a semi-infinite strip defined by the equation \(\frac{{\partial ^2 u}}{{\partial x^2 }} + \frac{{\partial ^2 u}}{{\partial y^2 }} = 0\) with boundary conditions \(u(0,y) = 0\), \(u(a,y) = 0\), and \(u(x,0) = f(x)\). The separation of variables method is employed, leading to the eigenvalue problem with eigenvalues \(\lambda_n = \left( \frac{{n\pi}}{a} \right)^2\) and corresponding eigenfunctions \(X_n(x) = B\sin\left( \frac{{n\pi x}}{a} \right)\). The solution is expressed as a series involving hyperbolic functions, with the need to specify boundary conditions as \(y \to \infty\) to ensure the function vanishes at infinity.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with boundary value problems and Dirichlet boundary conditions
  • Knowledge of separation of variables technique
  • Basic concepts of eigenvalues and eigenfunctions
  • Study the method of separation of variables in depth
  • Explore the properties of eigenvalues and eigenfunctions in PDEs
  • Learn about boundary conditions and their implications in solving PDEs
  • Investigate the behavior of hyperbolic functions as \(y \to \infty\)
Mathematicians, physicists, and engineering students dealing with partial differential equations, particularly those interested in boundary value problems and Laplace's equation.
Benny
Hi can someone please help me work through the following question. It is the two dimensional Laplace equation in a semi-infinite strip.
[tex] \frac{{\partial ^2 u}}{{\partial x^2 }} + \frac{{\partial ^2 u}}{{\partial y^2 }} = 0,0 < x < a,0 < y < \infty [/tex]
The boundary conditions along the edges are u(0,y) = 0, u(a,y) = 0 and u(x,0) = f(x) where f(x) is some prescribed function.
With my limited experience in dealing with PDEs at first glance I don't think there is enough information to even get to an expression for u(x,y) in terms of f(x) but I'll try this anyway.
Let [tex]u\left( {x,y} \right) = X\left( x \right)Y\left( y \right)[/tex] then
[tex] \frac{{X''\left( x \right)}}{{X\left( x \right)}} = - \frac{{Y''\left( y \right)}}{{Y\left( y \right)}} = - \lambda [/tex]
I have set the separation constant to be negative lambda because the boundary conditions suggest that I'll first need to work with the ODE in X(x).
The ODE in X(x) I get is
[tex]X''\left( x \right) + \lambda X\left( x \right) = 0[/tex] with X(0) = 0, X(a) = 0.
Dirichlet BCs so lambda is positive which gives me
[tex] X\left( x \right) = A\cos \left( {\sqrt \lambda x} \right) + B\sin \left( {\sqrt \lambda x} \right)[/tex]
The first BC implies A = 0 and avoiding trivial solutions the other BC yields the eigenvalues:
[tex] \lambda _n = \left( {\frac{{n\pi }}{a}} \right)^2 [/tex] where n is a natural number.
The corresponding eigenfunctions are [tex]X_n \left( x \right) = B\sin \left( {\frac{{n\pi x}}{a}} \right)[/tex]
The ODE in Y(y) is:
[tex] Y''\left( y \right) - \lambda _n Y\left( y \right) = 0[/tex]
Since lambda is positive [tex]Y_n \left( y \right) = C\cosh \left( {\sqrt {\lambda _n } y} \right) + D\sinh \left( {\sqrt {\lambda _n } y} \right)[/tex].
[tex] u_n \left( {x,y} \right) = X_n \left( x \right)Y_n \left( y \right)[/tex]
[tex] u_n \left( {x,y} \right) = \left[ {a_n \cosh \left( {\sqrt {\lambda _n } y} \right) + b_n \sinh \left( {\sqrt {\lambda _n } y} \right)} \right]\sin \left( {\frac{{n\pi x}}{a}} \right)[/tex]
[tex] u\left( {x,y} \right) = \sum\limits_{n = 1}^\infty {\left[ {a_n \cosh \left( {\sqrt {\lambda _n } y} \right) + b_n \sinh \left( {\sqrt {\lambda _n } y} \right)} \right]\sin \left( {\frac{{n\pi x}}{a}} \right)} [/tex]
The only other bit of information I have left is u(x,0) = f(x) so I try that to see what happens. But that just tells me that
[tex] f\left( x \right) = \sum\limits_{n = 1}^\infty {a_n \sin \left( {\frac{{n\pi x}}{a}} \right)} [/tex]
[tex] a_n = \frac{2}{a}\int\limits_0^a {f\left( x \right)} \sin \left( {\frac{{n\pi x}}{a}} \right)dx[/tex]
So that gives me a_n but what about b_n? I really don't know how to proceed. Can someone please help me out? Thanks.
You need to specify the B.C.'s as y->infinity. Probably they want the function to vanish, in which case you don't want to use sinh y and cosh y but instead e^y and e^-y, and only the e^-y terms will survive.
Yeah I think the BC for y going to infinity is missing but I think the condition is usually as you said, u tends to zero and y gets large. In that case I can rewrite the sinh and cosh in terms of exponentials and simply set the appropriate constants to be equal to zero. Thanks for the pointers.
  • · Replies 105 ·
13K
  • · Replies 47 ·
