Dirac's Delta as a derivative of the unit step
The discussion centers around the relationship between the Dirac delta function and the unit step function, particularly examining the claim that the derivative of the unit step function is the Dirac delta function. Participants explore definitions, properties, and implications of discontinuities in these functions, with a focus on theoretical and mathematical reasoning.
  • One participant argues that the derivative of the unit step function does not exist due to differing left and right limits at zero, suggesting a need to redefine the unit step function to yield a consistent impulse.
  • Another participant counters that taking the derivative of a discontinuous function is not valid in a strict sense.
  • A third participant notes that the Dirac delta function is not a function but a distribution, challenging the validity of the initial definitions provided.
  • Some participants introduce alternative perspectives, such as the n-th derivative of the delta function and its relation to the Fourier transform, and discuss the implications of differentiating functions with discontinuities.
  • There is mention of the Dirac delta function being defined as a linear functional that assigns values to functions in its domain, and that it can be shown to satisfy certain properties.
  • One participant questions whether the step function is already defined to take a value of 1/2 at zero, implying a potential ambiguity in definitions.
  • A later reply suggests integrating the Dirac delta function to illustrate its properties, emphasizing the infinite nature of the step increase it represents.
Participants express differing views on the definitions and properties of the Dirac delta function and the unit step function. There is no consensus on the validity of the initial claims regarding the derivative of the unit step function or the implications of discontinuities.
Limitations include the dependence on definitions of the Dirac delta function and the unit step function, as well as unresolved mathematical steps regarding the treatment of discontinuities in derivatives.
Ali 2
The Dirac detla or unit impulse function is defined as :
[itex]\delta (t) = \left \{ \begin {matrix} \infty \quad \ t = 0 \\ 0 \quad : \ t \neq 0 \end{matrix}[/itex]
and the unit step function :
[itex]u(t) = \left \{ \begin {matrix} 1 \quad \ t \geqslant 0 \\ 0 \quad : \ t < 0 \end{matrix}[/itex]
It is said that the
[tex]\frac d {dt} u(t) = \delta (t) [/itex] ..<br /> <br /> but .. if we came to the definition of the derivative , we should find the limit from left and right .. :<br /> <br /> [tex]{ \displaysytle u'_+ (0) = \lim { h \to 0^+ } \frac { u (0 + h ) - u (0) } h = \lim { h \to 0^+ } \frac {1-1} h = 0 }[/tex]<br /> <br /> [itex]{ \displaystyle u'_- (0) = \lim { h \to 0^- } \frac { u (0 + h ) - u (0) } h = \lim { h \to 0^- } \frac {0-1 }h = \infty}[/itex]<br /> <br /> We see that the derivative is infinity from left only .. and it is not equal to the right limit , so the derivative doesn't exist .. and it is not an imuplse ..<br /> <br /> But <b>IF</b> we define u (0) to be between 0 and 1 , For instance 0.5 , then :<br /> <br /> [itex]u'_+ (0) = \lim { h \to 0^+ } \frac { u (0 + h ) - u (0) } h = \lim { h \to 0^+ } \frac {1-0.5} h = \infty[/itex]<br /> <br /> Which makes the derivative from both sides infinity , which gives us the impulse ..<br /> <br /> As a result , we should chane the definition of the unit step function .. <br /> <br /> Do you agree with me ?[/tex]
No, because you cannot, strictly speaking, take the derivative of a discontinuous function in the first place.
Besides, what you have given as a "definition" of the Dirac delta "function" isn't any valid definition, nor is the Dirac delta "function" a function, it's a distribution.
- There're even more "bizarre" approach for example the n-th derivative of the delta function is equal to (Fourier transform):
[tex]2\pi D^{n} \delta (x) =\int_{-\infty}^{\infty}du(iu)^{n}e^{iux}[/tex]
By the way...why can't you differentiate a "discontinous" function?..for example you ca get the formula for the derivative of prime number function:
[tex]\frac{d\pi (x)}{dx}= \sum_{p}\delta (x-p)[/tex] and PNT theorems stablishes the asymptotic equality:
[tex]\frac{d\pi (x)}{dx} \sim 1/log(x)[/tex]
"ramanujan gave the formula"...(Mathworld)[tex]\frac{d\pi (x)}{dx}= \sum_{n>1}\frac{ \mu(n)}{n}x^{1/n}(log(x))^{-1}[/tex]and the derivative of any function that has a "jump" at a real number c the derivative can be interpreted as [tex]f'(x)\delta (x-c)[/tex] that you can check is oo..if we express the derivative in the sense of "distributions" you can define it even with discontinuities.
"if we express the derivative in the sense of "distributions" you can define it even with discontinuities."
Evidently, but then you've changed the sense of the term "derivative". :smile:
Well, no, that isn't the way the Dirac Delta function is defined. The "Dirac Delta function" is defined as the linear functional that, to every function f in its domain, assigns the value f(0). It can then be shown that the Dirac Delta "function" satisfies those properties. Yes, it is true,that the Dirac Delta function is the derivative of the Heavyside Step Function under the definition of "derivative" for "distributions" or "generalized functions".
Isn't the step function already defined as taking the value 1/2 when it's argument is zero anyway?
ad absurdum
I would answer by trying to intergrate the Dirac Delta.
The Dirac delta would give a step increase, but of infinite size and I am fairly certain that there would be no good way to determine at what point the step would fall.
That is to say the derivative of the unit step, u(t), or the unit step function times some constant, a*u(t), would yield the Dirac Delta for both:
u'(t) = delta = a*u'(t)
  • · Replies 25 ·
