Hyperreal Properties: Understanding the Archimedean Property & Superstructures
  • Context: Graduate
  • Thread starter Thread starter homology
The discussion revolves around the properties of hyperreal numbers, particularly focusing on the Archimedean property and the use of superstructures in mathematical logic. Participants explore various formulations of the Archimedean property, its implications for transfer, and the completeness property of the reals in relation to hyperreals. The conversation also touches on the distinction between internal and external elements within hyperreal analysis.
  • One participant notes different formulations of the Archimedean property, questioning their implications for transferability.
  • Another participant asserts that the formulation stating "n is finite" does transfer to "n is hyperfinite," challenging the initial claim.
  • A participant expresses curiosity about the treatment of expressions involving hyperreal numbers, such as \infty^{3}+\infty^{2}-\infty.
  • It is suggested that everything applicable to real numbers is also applicable to hyperreal numbers, with caution advised regarding internal versus external operations.
  • One participant requests clarification on the concepts of internal and external elements, indicating a potential gap in understanding.
  • A more constructive interpretation of internal and external is proposed, emphasizing the distinction between analytical descriptions and set-theoretic comparisons.
  • Concerns are raised about the limitations of the analytic power-set operation in nonstandard models, particularly regarding infinitesimals.
Participants express differing views on the transferability of formulations related to the Archimedean property and the definitions of internal versus external elements. No consensus is reached on these points, indicating ongoing debate and exploration of the concepts.
Participants highlight limitations in understanding the implications of certain definitions and operations within hyperreal analysis, particularly regarding the nature of internal and external elements and the completeness property.
This discussion may be of interest to those studying nonstandard analysis, hyperreal numbers, and the foundational aspects of mathematical logic and set theory.
homology
Hey folks,
I've been playing around with these (hyperreals) lately and have a couple questions. One concerns the Archimedean property. I keep finding different formulations of it. Some of them lend themselves to transfer. For example, if the AP is that for every real x there exists positive n such that |x|<n then this transfers nicely. Another formulation stipulates that n is finite which wouldn't transfer. Anywho, I'd like to get the sharp, orthodox take on this.
Question numero 2: So I've seen references to using superstructures and constructing a first order logic on the superstructure so you can talk about things like measures and what not. Now the completeness property of the reals (every bounded subset has...) seems as though it could be phrased in such a logic and then transferred?
I'm sure these questions reveal my naive understanding of the hyperreals. Math gods, be gentle...
thanks
"n is finite" does transfer. In (what I think is) the usual language, it transfers to "n is hyperfinite".
Of course, the definition of "finite" is usually "smaller in magnitude than some natural number".
Yep. Every bounded internal set of hyperreal numbers has a least upper bound, et cetera.
I'm very curious about this "Numbers"?..in fact could you treat expression using hyperreal numbers in the form:
[tex]\infty^{3}+\infty^{2}-\infty[/tex] or define
[tex]exp(\infty^{3})-sin(\infty)+|\infty|[/tex]
Essentially everything you can do with the real numbers, you can do with the hyperreal numbers. Everything you can't do with the real numbers, you can't do with the hyperreal numbers. (Though in both cases you have to be careful about doing things "internally" and not "externally")
In particular, [itex]+\infty[/itex] serves the exact same role in nonstandard analysis as it does in standard analysis, and thus expressions like
are undefined.
Externally speaking, there are infinite hyperreals ([itex]+\infty[/itex] is not a hyperreal), and you can do all the arithmetic you want with those.
Thanks Hurkyl
Thanks Dude,
Another question oh fountain of mathy knowledge. Could you give me a quick breakdown of internal and external? Just rough is fine. I see that I've missed something important.
cheers,
Kevin
The dictionary definition is that something is internal if and only if:
(1) It is the *-transfer of something standard
(2) It is an element of an internal set
(so this is a recursive definition)
I prefer a more "constructive" interpretation, though -- something is internal if and only if you can describe it analytically. If you must resort to something else (such as comparing the reals to the hyperreals, or invoking pure some pure set-theory), it's external.
In particular, the analytical power-set operation is not the set-theoretic power-set operation. (I think that was my biggest stumbling block in trying to understand this stuff) The analytic power-set operation only gives you internal subsets -- but the set-theroetic power-set is capable of giving you any external subset.
The standard model of analysis is the only one in which the analytic power-set coincides with the set-theoretic power-set. In any nonstandard model, the analytic power-set is "missing" some sets.
For example, the set of all infinitessimals is not an element of the (analytic) power-set of the hyperreals.
P.S. if you're algebraically minded, you might try studying the (related, but simpler) theory of real closed fields first; for me, that really illuminated the ideas from formal logic that are at work here.
  • · Replies 24 ·
  • · Replies 21 ·
  • · Replies 37 ·
10K
  • · Replies 19 ·
  • · Replies 34 ·
14K
10K
