How Do Dynamics and Algebra Interact in the Study of Affine Varieties?
  • Context: Graduate
  • Thread starter Thread starter phoenixthoth
    Algebra Dynamics
The discussion explores the interaction between dynamics and algebra in the context of affine varieties, particularly focusing on the properties of varieties generated by polynomials in the complex numbers. Participants examine how the dynamics of a polynomial function relates to the structure of associated ideals and varieties.
  • One participant introduces the concept of an ideal generated by the differences of iterates of two polynomials, f and g, and proposes investigating the properties of the associated variety V[f,g].
  • Another participant suggests that setting g=x might lead to interesting results regarding periodic orbits of f, although they express uncertainty about the implications of their conjecture.
  • A later reply questions the earlier assertion about the non-emptiness of the variety, noting that the radical ideal generated may not be prime and that the relationship between f and g needs further clarification.
  • One participant draws an analogy between the polynomial f and a projection operator, suggesting that certain conditions on f could imply the existence of zeros in the ideal.
  • Another participant counters that every polynomial has fixed points, which complicates the assertion about the uniqueness of zeros satisfying f(x)=f(f(x)).
  • Discussion includes the observation that for polynomials of the form f(x)=x+b (with b non-zero), there are no fixed points, which leads to a different behavior in the context of the ideals.
Participants express differing views on the implications of the properties of polynomials and their associated ideals. There is no clear consensus on the nature of the varieties or the conditions under which they are non-empty.
Participants note limitations in their assertions, particularly regarding the uniqueness of zeros and the nature of the ideals generated by polynomials. The discussion reflects a range of assumptions and conditions that are not fully resolved.
phoenixthoth
it's an interaction between dynamics and algebra.
let f and g be elements of C[x] where C is complex numbers (or any alg. closed field).
denote the nth iterate of f by f^n, though that notation is often also used for the nth power of f. (this is where the dynamics of f is involved.)
consider the ideal (and affine variety) generated by f-g, f^2-g, f^3-g, ... . denote this by I.
the hilbert basis theorem states that this can be generated by a finite number of elements in I. denote this finite generating set by [f,g], not to imply that the generators are f and g. then the variety associated with I is the same as the one associated with <[f,g]>, the "span" of [f,g]. denote the variety by V[f,g].
i want to investigate properties of V[f,g] depending on f and g. the easiest case is if f is a constant function. then its hilbert dimension is easy to calculate. if f is linear, things get a lot more interesting already. i imaging that for most or all g, V[f,g] is empty, but I'm not sure.
any thoughts?
well, i was hoping this approach might shed some light on the dynamics of f and my ultimate goal would be to say something like f "converges" to g if V[f,g] is of maximal dimension and "does not converge" if for all g, V[f,g] is empty. something like that.
if we let g=x then could something interesting come out of that? perhaps the result that if f has any period r orbits where r is finite then all points have a bounded period (i guess that follows because f is in C[x])? this is all in the "making mistakes in different directions" so i hope you'll excuse the conjecture-like, random nature of my questions.
Deleted that post cos most of it was unimportant and misleading, but the idea that varieties do not distinguish between the ideals I and I^2 is important. In fact the reason I deleted it was because I realized in fact that my assertion that something was going to be non-empty was probably wrong. There was no reason at all for the rad ideal generated to be prime.
A prime ideal is maximal in C[x] and the only such is <(x-a)> for some a (well, non-trivial I mean).
In general, considering the difference of two elements, f^r - f^n is in the ideal. so a zero of this is a point with period n-r. this is true for all r,n, and in particular for n-r=1. So the zeroes of the ideal are some subset of the points with f(x)=f(f(x)). But for the reverse to be true, it must be that f(x)=g(x)
So it must be that f-g has a unique zero that satisfies f(x)=f(f(x)).
and i think that is enough to characterize when varieties occur, and what they are.
in that case, f is like a projection operator in that f(x)=f(f(x)). hence f must map some subset of C to itself. for example, f could map the unit disk to itself or C to itself. i mean that these are conditions on f that imply f(x)=f(f(x)) and that the ideal has zeros, i think.
i spotted your misprint as well, or i shall say i doubted it, but i think i'd like to just speak my mind regardless of whether it's correct. when one of us makes an error, we can correct each other. that way, the imagination can be free to roam though checked by the balance of the other person. it's up to you.
this f though is just a polynomial, and every polynomial has some set of x with f(x)=x (with the obvious exception), approx deg f of them give or take. And
checking f=g has at most max(deg f,deg g) solutions.
So it is nothing special to require f(x)=f(f(x)) cos every f will have some (finite number of points) where this is true. (at most [deg f] squared). So I wouldn't say 'in that case' because that is almost always the case. interestingly the exception is f(x)=x+b for b non-zero. but if b's non-zero then the previous argument applies (from the deleted post) that the ideal contains the functions
x+b -g
x+2b-g, and thus all the constant functions, and the ideal is C[x]
right because for that function, when b!=0, there are no fixed points.
  • · Replies 19 ·
  • · Replies 25 ·
