Surface of the lense and temperature
  • Context: Undergrad
  • Thread starter Thread starter SAZAR
    Surface Temperature
The discussion revolves around the relationship between the surface area of a circular convex lens and the temperature achieved at its focal point when focusing sunlight. Participants explore practical approaches to achieving high temperatures, such as 3000 degrees Celsius, using lenses, while also considering the implications of heat transfer and energy concentration.
  • Exploratory, Technical explanation, Debate/contested, Experimental/applied
  • One participant inquires about a formula relating lens surface area to temperature at the focal point, suggesting it may involve the power of sunlight per unit area.
  • Another participant asserts that a perfectly transparent lens can only equal the source temperature and cannot exceed it.
  • A participant questions how to achieve extremely high temperatures at the focal point and asks about the necessary size of the lens.
  • It is suggested that any size converging lens can focus sunlight to achieve high temperatures, but heat loss must be minimized to reach desired temperatures.
  • One participant expresses frustration at the complexity of the question, emphasizing the practical nature of their inquiry regarding lens size and energy concentration.
  • A later reply discusses the heat transfer problem, noting the importance of balancing heat supply and loss to increase temperature.
  • Another participant highlights the complexity of the problem, mentioning factors like thermal conductivity and the need for practical testing.
  • Participants discuss specific scenarios, including hypothetical conditions for melting a material at high temperatures and the calculations required to determine lens size.
  • Questions arise about the heat capacity of the material in question and the energy needed to raise its temperature, with references to sunlight's energy at the Earth's surface.
  • Clarifications are sought regarding terminology, particularly the difference between melting and fusion.
Participants express differing views on the feasibility of achieving high temperatures with small lenses, the importance of heat loss, and the complexity of the calculations involved. The discussion remains unresolved with multiple competing perspectives on the practical application of lenses for high-temperature scenarios.
The discussion includes assumptions about the properties of materials and the conditions under which the lens operates, such as sunlight intensity and heat transfer dynamics. Specific mathematical steps and parameters remain undefined, contributing to the complexity of the inquiry.
SAZAR
What is the formula that relates surface (m^2) of a circular convex lense with temperature (Celsius) in a light focus point of a lense.
(calculating temperature in the light focus according to size of a lense...)
(Glass lense, regular... (so, no coefficients, just assume it's some nice common average colourless glass lense... Some simple forumula, something practical - you get what I mean...))
(I guess it relates [power of sunlight]per[unit of surface]...)
Example, please... :smile:
(...and formula for mirror used instead of lense to concentrate light (I guess it's a better solution, but nevertheless I prefere lense))
Link if there is a place you know where I could find it (it's a too complex concept, google gives me all sorts of irrelevant results)
Thank you in advance.
Science news on Phys.org
SAZAR said:
(snip)(I guess it relates [power of sunlight]per[unit of surface]...)
(snip)
Good guess --- a perfectly transparent lens, or perfectly reflecting mirror, concentrates power only from the area it intercepts. That means, power is a function of source power per unit area at the interception distance. Temperature? Can only equal the source temperature, never exceed it.
O', sorry - maybe I've used a wrong term.
What I've ment to ask is: how to achive some silly high temperature such as e.g. 3000 Celsius degrees at the light focus spot using a lense?
(how huge the lense must be in order to do that?)
Any size converging lens focusing sunlight will do that. Heat loss from the point at which the light is focused reduces the temperature you actually achieve; reduce the heat losses, and you raise the temperature.
...And I've thought I was asking a simple question...
I was not asking a theoretical question; I was asking a practical question.
...If we imagine (for ilustration purposes) that Sun-light shining on ground consists of lines of some density running into ground (density of those hypotetic lines define how strong it's shining), then putting a bigger (say 0.5m diameter) lense "catches" more of those lines (and concentrates energy of all of them into a single point), than some small (say 1cm diameter) lense would...
...And you are telling me that a 1cm diameter this-world plain-old glass lense can heat some object (natural magnet for instance) in the focal point on it to 3000 Celsius degrees...
I don't know, but somehow two words (for some strange reason) come to my mind... leg and pull...
It's a heat transfer problem: supply heat to an object at a fixed rate; restrict heat loss from the object to a rate less than that of the supply; the object increases in T. Boil the Earth's oceans with a flashlight --- it's going to take on the order of 1021 to 1022 years.
You want lens sizes? You're going to have to come up with time constraints, methods to control heat loss, heat capacities for whatever you're cooking, and a couple other parameters.
It is very dependent upon things like thermal conductivity, coefficient of expansion, and thickness gradients. This is a pretty complicated question with a number of variables. Your garden variety engineer would field test this application in a heartbeat. The company would go bankrupt waiting for the scientist to perfect the math. Engineers assume Ms. nature will invariably toss you a curve ball on a full count. . . e.g., spare part kits tend not to include more than one of the least expensive part most likely to be lost at the job site.
I went to a customer facility once to replace a 50 hp motor. We took every precaution to guarantee the safe arrival of the motor. The plan worked to perfection. The motor mount bolts - 4 required - was a different story. My parts kit included exactly 4 bolt assemblies - bolts, washers, nuts, etc., which cost a total of 5 bucks. After spending half a day unloading and transporting the motor to the machine, I dropped one of the bolts, which fell about 5 stories before making a faint, but distinct, splashing sound. Not good.
OK, you have a perfectly sunny summer day on Earth (exactly halfway between northpole and equator) at noon, and exactly 5 seconds (not more not less) to melt 1kg of some hypotetic pitch-black material (90% of all rays are absorbed; conducts heat like concrete; dimnsions 1x1x1dm) that melts at 3000 C degrees. What is the diameter of a convex glass lense you would use? THINK FAST!
What is the heat capacity of the material in question? That is, how many joules or calories does it take to raise one gram of it by one degree in temperature?
Once you know that, you can calculate how much energy in joules you need, as a minimum (not taking radiation losses into account); the required time then gives you the required joules per second.
Sunlight at the Earth's surface carries about 1400 or 1500 joules of energy per second, per square meter perpendicular to the sun's rays. Comparing this with the result from the preceding paragraph gives you the number of square meters needed.
Well, as I've mentioned that it "conducts heat like concrete", then let's say same as concrete.
So what is the diameter for this particular example?
You haven't given us a heat of fusion for your "hypothetical material."
Fusion?
What fusion now?
You mean melting?
What do you mean by 'fusion'?
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 25 ·
  • · Replies 207 ·
16K
  • · Replies 40 ·
