Verifying True/False Answers: Justification Required
  • Thread starter Thread starter mr_coffee
The discussion revolves around verifying the truth values of various mathematical statements and providing justifications for those evaluations. The subject area includes logic, quantifiers, and properties of real numbers.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the implications of quantifiers in mathematical statements, questioning how to properly justify claims about truth values. There are discussions about counterexamples and the necessity of proving statements for all cases versus finding a single counterexample.
Participants are actively engaging with each other's reasoning, with some providing clarifications on the use of quantifiers and the nature of proofs versus counterexamples. There is a recognition of the need to understand the distinction between proving statements universally and disproving them with specific examples.
Some participants express confusion regarding the professor's explanations about quantifiers and the requirements for proving or disproving statements, indicating a need for further clarification on these concepts.
mr_coffee
Hello everyone. I have a series of statements I'm suppose to indicate which of the following statements are true and which are false. I am then suppose to justify my anser the best i can...
Here are some of the ones i did, can you verify they are correct? They seemed to easy for them to be right
http://img221.imageshack.us/img221/6697/lastscangb9.jpg
http://img209.imageshack.us/img209/3370/lastscan2pt4.jpg
Thanks!
Your answers to c, d, and h are wrong, and your reasons for your answers to g and i are faulty. For g, you shouldn't say "z is an integer", you should say, "x - y is an integer because x and y are integers and differences of integers are integers, so let z = x-y, and that proves the claim." The idea is to find an integer z, not say that z is an integer; do you see the difference? For i, the questions asks something about ALL v, so you should not be proving things about a particular v, like v=1.
Thanks for the responce!
I do see the difference but I'm having troubles getting it for all cases. Can i say somthing like, let u and v be positve real numbers such that u < v, then (u)(v) < v ?
Is C false because of counter example, if u let y = x, then x cannot equal y+1?
For part D, i don't see why it isn't false, doesn't that show a counter example, when xy is not equal to 1, given 2 year positive numbers?
You are not paying attention to your quantifiers.
For all means you need to do it for all, there exists mean you need to find one thing.
For instance when showing
for all v in R+ there is a u in R+ such that uv<=v
you cannot just pick *one* v and say it is true because it is true for one v.
Similarly, for the uv=1 question, look at the quantifiers: for all u inR+ there is a v in R+ with uv=1. your 'counter' example of u=1 v=3 doesn't matter. A counter example would be: there exists a u in R+ such that for all v in R+ uv=/=1, which is obviously false.
"There exist x such that for all y, x+ y= 1."
Can the same make that true for both y= 1 and y= 2?
That is, x+1= 1 and x+ 2= 1.
I remember the professor saying you can disprove somthing if you find 1 counter example, but to prove somthing you must prove it for all cases. If i have somthing like #40 part h, Where i have the existence quantifier first, doesn't that mean, I only have to prove 1 counter example to make that whole statement false which i supplied?
There exists a real positive number u such that For all real positive numbers v has the property uv < v. This is false because if you let u = 1, v = 3. Then 3 is not less than 3 which makes this statement invalid. because they just said There exists 1 real u, for ALL positive numbers v which is a strong statement to make isn't it?
And if i have the For all quanitifer first in a statement, and then an existence statement like matts exampe:
THen I must suppply a counter example for all cases to make the statement false, is this correct? I must hae misunderstood what the professor ment when he said 1 counter, or it must be for only a certian case.
Thanks for the help guys.
You showed that for some v and u, but you need to show it for all v (and some u).
A counterexample would be some v for which there exists no u (but if the statement is true, you can't find this).
You have to show what the quantifiers tell you.
If you are asked to show
for all x blah blah blah
then you have to show it for all x. If you need to disprove it a single counter example for one x will suffice.
If you're asked to show
there is a y such that...
then you need to show at least one y exists, possibly by writing it down, so that the 'such that...' is satisfied. If you need to disprove it then you need to show that *no* possible choice of y will work, not just something you pick arbitrarily.
The moral: look at the quantifiers, they tell you precisely what you need to show.
To put what matt grime said in more technical terms:
[tex]\~(\forall p)= \exists(\~p)[/tex]
and
[tex]\~(\exists p)= \forall (\~p)[/tex]
Are there supposed to be some 'not' symbols there?
Actually, there are. There is a little "tilda" above each. I wanted a tilda (~) in front but couldn't figure out the LaTex.
It is \sim. What is there doesn't show up very clearly on my screen.
[tex]\sim(\forall x)= \exists \sim x[/tex]
the logical symbol is
[tex]\neg (\forall x) = \exists \neg x[/tex]
Ahh thanks for the explanation guys! I think in time i will get the hang of it hopefully!
  • · Replies 17 ·
