Answers to Your Questions: What Is an FIR Filter?
  • Thread starter Thread starter meldave00
    Filter
An FIR (Finite Impulse Response) filter is a type of digital filter that generates its output based solely on a finite number of previous input values, such as the last 10 clock ticks. FIR filters can be designed to perform various functions, including highpass, lowpass, and bandpass filtering, by customizing the polynomial calculations used in their input-output relationships. In contrast, IIR (Infinite Impulse Response) filters depend on both past input values and previous output values, allowing them to maintain a memory effect, which can lead to more complex stability issues and sharper filter skirts.
  • Understanding of digital signal processing concepts
  • Familiarity with filter design techniques
  • Knowledge of polynomial calculations in signal processing
  • Basic grasp of the differences between FIR and IIR filters
  • Research FIR filter design techniques using tools like MATLAB or Python's SciPy library
  • Explore the implementation of IIR filters and their stability considerations
  • Learn about the mathematical foundations of digital filter design, including z-transforms
  • Investigate applications of FIR filters in real-world scenarios, such as audio processing or telecommunications
Engineers, digital signal processing practitioners, and anyone involved in designing or implementing digital filters will benefit from this discussion.
meldave00
Can someone explain to me in leyman's terms what an FIR filter is and what it is used for?
A finite impulse response filter is one form of a digital filter. It bases its output value at each clock tick on the input values that it has seen over some previous amount of time (like the last 10 clock ticks, for example). You can design the polynomial calculation that the filter is using for its input --> output function so that you perform a highpass, lowpass or bandpass function on the digital data.
FIR filters are contrasted with infinite impulse response filters (IIR), where the output is dependent on the input data stream, and also dependent on previous output values. It's like the IIR filter has some memory, which means that a single impulse at the input can cause the IIR output to keep on changing forever. IIR filters can have sharper skirts on their filter function compared to FIR filters, but they are also harder to make stable.
Here's a related wikipedia article FYI:
http://en.wikipedia.org/wiki/Digital_filter
Thanks. I appreciate it.
  • · Replies 46 ·
  • · Replies 39 ·
