How Fast Does a Girl Enter the Water When Diving from a 15m Platform?
  • Thread starter Thread starter meawinner
    Stuck
The discussion focuses on calculating the entry speed of a girl diving from a 15-meter platform. Using the physics formula v = a * t, where a is the acceleration due to gravity (-9.8 m/s²) and t is the time in seconds (1.75 s), the final velocity is determined to be -17.15 m/s. The negative sign indicates downward motion. The initial velocity is zero, simplifying the calculation and confirming the use of basic kinematic equations.
  • Understanding of basic kinematics
  • Familiarity with gravitational acceleration (9.8 m/s²)
  • Knowledge of velocity as a vector quantity
  • Ability to manipulate algebraic equations
  • Study the kinematic equations for uniformly accelerated motion
  • Learn about vector quantities and their significance in physics
  • Explore real-world applications of gravitational acceleration
  • Practice solving problems involving free fall and projectile motion
This discussion is beneficial for high school physics students, educators teaching kinematics, and anyone interested in understanding the principles of motion under gravity.
meawinner
Hi this is an AS physics question that i am stuck on. I tried it but I don't get the answer it says in the answers.
A girl diving froma 15m plstform wishes to know how fast she enters the water. She is in the air for 1.75s and dives from rest(with an initial speed of zero). What can you tell her about her entry speed?
I tried to do speed=distance over time
Then I used acceleration is final velocity-initial velocity over time. But neither worked so can some1 please help me. Thanks
Hello meawinner,
Since Vf = Vi + a t, and the acceleration is just that of gravity, it is a simple calculation.
Vf=Vfinal, Vi=Vinitial, a=acceleration, t=time.
Alternately, you could us the formula Vf = Vi + sqrt(2 a d)
Hi there,
It sounds like you are on the right track with using the equations for speed and acceleration. However, in this scenario, the girl's initial velocity is zero, so we can simplify the equation to just:
v = a * t
where v is the final velocity (or entry speed in this case), a is the acceleration due to gravity (which is -9.8 m/s^2 for objects falling near the Earth's surface), and t is the time in seconds.
To solve for v, we can plug in the values given in the problem:
v = (-9.8 m/s^2) * (1.75 s)
This gives us a final velocity of -17.15 m/s. Since velocity is a vector quantity, the negative sign indicates that the girl is moving downwards (or in the direction of gravity) when she enters the water.
I hope this helps you understand the problem better. Keep up the good work and don't be afraid to ask for help when you need it!
