| Thread Closed |
boolean help. adder and subtractor |
Share Thread | Thread Tools |
| Jan26-04, 04:25 PM | #1 |
A boolean circuit has 4 inputs, a, b, cin and K. when K=0, the circuit is an adder. When K=1, the ciruit is a subtractor. WHere do I start? [o)] [*(] [g)] [?]
| Jan26-04, 09:07 PM | #2 |
Depends on what you're trying to do and what you already know. I imagine you want the circuit for your adder/subtractor, right?
There are lots of ways to go: You could build an adder, a subtractor, and a chooser circuit. You could make a truth table and build the circuit from that. You could analyze the difference between the circuits of an adder and a subtractor and hack it to provide the toggling capability. |
| Jan26-04, 10:28 PM | #3 |
i'm not trying to make a REAL circuit, I just need to know the boolean equation and schematic. I already know what full adder and subtractor look like. I just don't know how to toggle between the two with a 4th input K.
| Jan26-04, 10:35 PM | #4 |
Well, my post still applies if you replace "circuit" with "formula".
| Jan27-04, 01:42 AM | #5 |
not helping[*(]
| Jan27-04, 02:44 AM | #6 |
| Jan27-04, 06:34 AM | #7 |
Well, there are two cases, right?
K is false and the formula gives the output of an adder or K is true and the formula gives the output of a subtractor |
| Jan27-04, 02:06 PM | #8 |
still not helping. ur just restating my question. I already know there are 2 cases and that k=0 then it is an adder.
| Jan27-04, 02:14 PM | #9 |
Consider the naive approach: multiplex the outputs of each, as Hurkyl said.
A two-bit multiplexor looks like this: (m & s) | (n & ~s) where & is AND, | is OR, and ~ is NOT. m and n are the two inputs, and s is the select signal. Does this make sense? If you want to make the simplest possible formula, replace m and n with the formulas for a 1-bit adder and a 1-bit subtractor. Finally, do all the boolean simplification you can. Another approach would be to write out a truth table for the whole design -- a K-map -- and do the normal K-map stuff to get the equation. - Warren |
| Jan27-04, 02:32 PM | #10 |
(~K & (formula for adder)) | (K & (formula for subtractor)) |
| Jan27-04, 02:45 PM | #11 |
Thanks i kinda get it now. what is "~"?
| Jan28-04, 02:40 AM | #12 |
~a = !a = not(a) |
| Jan28-04, 12:19 PM | #13 |
not is an inverter right?
| Jan28-04, 12:37 PM | #14 |
Yes, it's an inverter. David, you seem to be completely unprepared to handle this problem. Why? Are you in a class where this was asked? Are you not paying any attention to the lectures?
- Warren |
| Jan28-04, 05:44 PM | #15 |
Here, I'll give you a hint to get you started:
Think "2's compliment subtraction" |
| Jan30-04, 12:31 AM | #16 |
I have been paying attention in class. It is just that my prof. cares so much about me and the students about getting a job after grad. that he teaches some extra stuff that we're not suppose to learn in ece 204. I'm not sure if I should cuss him out or thank him.[g)]
| Jan31-04, 02:07 AM | #17 |
what is a weighted code (BCD related) and how does it relates to gray code?
| Thread Closed |
| Thread Tools | |
Similar Threads for: boolean help. adder and subtractor
| Adder and Subtractor Unit | Electrical Engineering | 1 | ||
| Boolean rings and Boolean algebras | Set Theory, Logic, Probability, Statistics | 2 | ||
| How to use 4-bit parallel adders to perform 2Cs' subtraction? | Electrical Engineering | 2 | ||
| 4-bit binary subtractor | Electrical Engineering | 7 | ||
| Full adder boolean logic question | Electrical Engineering | 3 | ||
