Chain rule with table of values
The discussion revolves around applying the chain rule in calculus, specifically in the context of a function defined by a table of values. The original poster is tasked with filling in missing values related to the derivatives of functions defined in terms of each other.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the chain rule, with the original poster attempting to apply it to a composite function. There are questions about the correct substitution of values from the table and how to handle the derivatives of the nested functions.
Participants are actively engaging with each other's reasoning, identifying mistakes in the application of the chain rule, and exploring different interpretations of the function's derivatives. Some guidance has been offered regarding the correct form of the derivatives and the need to clarify the arguments of the functions involved.
There is confusion regarding the values in the table and how they relate to the derivatives being calculated. Participants are also grappling with the implications of substituting different values into the functions and the resulting calculations.
trajan22
ok firstly i understand how the chain rule works however I am given this table
x f '(x) g(x) g'(x) h'(x)
0 7 2 ___ 32
2 8 0 -3 ___
im told to fill in the blanks where h(x)=f(g(x^2-x))
this problem has become an annoyance at first i assumed to solve i would take f ' * g '(x)*x ' however this doesn't work and no form of multiplication will give me the correct answer when i multiply them together so I am guessing there is addition or subtraction involved. Please help as this is the only problem i am stuck on and the test is tom.
Hello trajan22,
you didn't apply the chain rule correctly. Maybe it would help you to see where you've made the mistake, if you write down the arguments of all functions as well.
Regards,
nazzard
i think i found my error in the application if I am right then it should be
f '(g(x))* g' (x)* (x')
this would translate to for the second row
8*2*-3*2
however this doesn't bring me to the right answer i think the problem is in the x^2*x do i sub in 2 for this for every part of the operation involving x or do i take the table value ex. g'(x)=-3 or g'(x)=-3(2^2-2)or -6 I am thinking this is where the problem lies. what are your thoughts
You still got the arguments/variables wrong. You could try to rename (x^2-x) to y(x). Then h(x) would be: h(x)=f(g(y(x))). Can you see now that you didn't apply the chain rule correctly to the y(x) part and that the arguments should read y(x) and not simply x?
sorry I am still havin trouble with it because since g(x) is 0 then the outcome would be 0 because you multiplyby 0 obviosly this isn't the case...
but with the new argument is it
8*(-3*(2))*(0(2))*-3(2)(3)*(3)??
8*(0*(2))*(-3(2))*(-3(2))(2)??
That doesn't seem to be correct.
Before plugging in any values, please make sure you have the correct answer for h'(x).
h'(x)=f'(g(y(x))*g'(y(x))*y'(x).
with y(x)=x^2-x.
What is y'(x)?
y'(x) should be 2 right? because x^2-x would be 2^2-1 or just 3? because y'
is 2x-1
is 2x-1
y'(x)=2x-1
Now, as a result we have:
h'(x)=f'(g(x^2-x))*g'(x^2-x)*(2x-1)
What is h'(0)? To find out, you just replace every x with 0, right?
So you'll get:
h'(0)=f'(g(0^2-0))*g'(0^2-0)*(2*0-1)
h'(0)=f'(g(0))*g'(0)*(-1)
i follow what you are saying but still end up with a result of zero when it should be -21 I am missing something obvious...ps thank you for all your help i really appreciate it
No problem. :smile:
I'll try to cover it step by step.
We have:
We have a look at the table and find:
h'(0)=32, g(0)=2
So we put that information in our equation and get:
32=f'(2)*g'(0)*(-1)
luckily the table also provides us with the value for f'(2), it's 8.
So we get:
32=8*g'(0)*(-1).
You can solve for g'(0) and write the value into your table.
Can you go from there and solve the equation for h'(2)?
well now i see how the answers are brought about but i didnt realize that you could deal with this by leaving the row such that f'(0)=8 but f'2 =7 what is the reasoning behind this if x is a different value because the way i thought it was i f'0=7 and f'2 =8 but this is not the case so I am confused on the underlying concept...also for 32=8*g(-1) i get -4 but the answer is supposed to be just 4 32=-8g -4=g I am also getting the opposite sign for h as 21 not -21
Hmmm, starting with this table and h(x)=f(g(x^2-x)) I don't get 21 or -21 as an answer for h'(2). :frown:
x__f'(x)__g(x)__g'(x)__h'(x)
0___7____2_____??___32
2___8____0____-3____??
Maybe I've done something wrong along the way? I'll have another look.
well this is how i figured it for h'2 since f'=gx it is f'=2(0^2-0)so f' is 0 so therefore for at f'0 according to table it is 7 then 7*g' is -21(correct answer) but for some reason -21*-1 gives 21 this is the way i reasoned it hope you can follow.
Ok I can't seem to follow you here and I had problems with your notation in another post as well. What does f'=gx and f'=2(0^2-0) mean? :redface:
for h'(2) I get:
h'(2)=f'(g(2^2-2))*g'(2^2-2)*(2^2-1)
h'(2)=f'(g(2))*g'(2)*(3)
h'(2)=f'(0)*(-3)*(3)
h'(2)=8*(-3)*(3) *wrong*
:rolleyes:
*edit: I get h'(2)=7*(-3)*(3) since f'(0)=7.*
oh sorry about that now that i look at it again f'=g(x) doesn't make sense...but the 2is the value at g(x) and 0 is the value at x so i input this into 2*(x^2-x)which is g'(x^2-x)
which gives the value of 0
so that makes it f'(0) so i took this value from the table at f'(0) to be 7and multiplied it by g'(x) and returned with -21 i then multiplied by -1 as that is what x' is therefore i got 21...i did the same operation for the first colum to get g
i hope this you can follow this ...
WELL CANCEL THIS, IM GETTING THE RIGHT NUMBER BUT I REALIZED THAT IT IS MULTIPLIED BY 3 AT THE END BECAUSE 2X-1=3 WHEN X IS 2 SO THIS INVALIDATES MY ARGUMENT. AND WOULD CHANGE IT TO 63
My final table looks like this:
0___7____2____-4____32
2___8____0____-3___-63
I'm still not sure where the mismatch with the signs comes in. :rolleyes:
right that's what I am getting and also a friend of mine who worked the problem ...my only guess at this point that the answer sheet is wrong with the h'(x) value being 21 and the g'(x) value being 4. oh well...you still helped with the comprehension of this style of problem so thanks again...
