One question about stream function in fluid mechanics
The discussion centers on the uniqueness of the stream function in fluid mechanics for a circular cylinder moving with constant velocity U in a two-dimensional unbounded, irrotational, incompressible, inviscid fluid. The velocity field is described by the components (ψ_y, -ψ_x), where ψ is the stream function. The participants confirm that while one solution is ψ = y U R^2/(x^2+y^2), another valid solution is ψ = y U R^2/(x^2+y^2) + log((x^2+y^2)/R^2), both satisfying the Laplace equation and boundary conditions. The discussion concludes that the stream function is not unique, as it can differ by a constant term.
  • Understanding of fluid mechanics principles, specifically irrotational and incompressible flow.
  • Familiarity with the concept of stream functions and their role in fluid dynamics.
  • Knowledge of the Laplace equation and its applications in potential flow theory.
  • Basic understanding of boundary conditions in fluid mechanics.
  • Study the derivation and applications of the Laplace equation in fluid dynamics.
  • Explore the concept of stream functions in more complex flow scenarios.
  • Investigate the implications of moving reference frames in fluid mechanics.
  • Learn about potential flow theory and its applications to various geometries.
Fluid mechanics students, researchers in hydrodynamics, and engineers working on problems involving potential flow and stream functions will benefit from this discussion.
aqualonebear
Hi...
Suppose we consider a circular cylinder moving with constant velocity U in x-direction in a two-dimensional unbounded, irrotional, incompressible, inviscid fluid. If the motion of the fluid is completely resulted from the motion of the body, we know the velocity field of fluid can be described by ( \psi_y, -\psi_x), where \psi is the stream function which satisfys the boundary condition
\psi = y + constant, on the cirlce
and also
( \psi_y, -\psi_x) goes to zero as (x,y) goes to infinity
and it satisfies the laplace equation as well.
My question is , is this stream function unique up to a constant?
Actually if the radius of the circle is R, one solution of \psi is
\psi = y U R^2/(x^2+y^2).
But I think
\psi = y U R^2/(x^2+y^2) + log ((x^2+y^2)/R^2) for (x,y) in fluid domain (outside the cyliner)
is also a solution since it satisfies all the conditions.
Thanks a lot.
A cylinder moving at constant velocity is not a steady state problem. It would have to be evaluated from a frame of reference moving with the cylinder to be considered steady state (and have a stream function solution).
  • · Replies 51 ·
10K
  • · Replies 20 ·
  • · Replies 18 ·
