What is the Electric Field Magnitude at a Charged Ball's Position?
The discussion centers on calculating the electric field magnitude at the position of a charged plastic ball influenced by a nearby charged glass rod. The ball, with a charge of -5.13 microCoulombs, experiences an electric force of 0.6672 milliNewtons. The correct formula to use is E = F/Qo, where E represents the electric field, F is the electric force, and Qo is the charge of the ball. The user successfully applied this formula after addressing unit conversions, confirming the relevance of the electric force and charge in determining the electric field.
  • Understanding of electric fields and forces
  • Familiarity with Coulomb's Law
  • Basic knowledge of unit conversions in physics
  • Proficiency in using formulas for electric field calculations
  • Explore the concept of electric field strength and its applications
  • Study Coulomb's Law and its implications in electrostatics
  • Learn about unit conversions relevant to electric charge and force
  • Investigate the effects of distance on electric field intensity
Students studying physics, particularly those focusing on electrostatics, as well as educators and anyone looking to deepen their understanding of electric fields and forces in charged systems.
Zypheron
I'm having a problem with one of my physics problems.
A plastic ball of radius 5 cm is hanging from a string 2m away from a charged glass rod. The ball has been charged to -5.13 microCoulombs. If the electric force on the ball is 0.6672 milliNewtons in the horizontal direction, what is the magnitude of the electric field at the balls position?
I've worked at it by using E = F/Qo, but it just doesn't seem to be working out ><. I'm not looking for an answer, I'm looking to see if i am going about this problem in the right way.
I presume this is part of a more extensive problem because, the way the problem is phrased, neither the radius of the ball nor the distance to the glass rod is relevant.
Yes, E= F/Q0= 0.6672 milliNewtons/(-5.13 microCoulombs). If that's not the correct answer, check to see if you need to convert units.
Yeah, those tricksy tricksy physics professors like to give the useless info. I ended up getting it right in the end and such (stupid lab quiz required that i use a direction, although it was implied by the positive and negative x-axis ><. Thanks for the help though. I was getting really really stressed out about it (needed to get that one so i could go to my lab today)
  • · Replies 22 ·
