Calculating Coyote's Canyon Landing Point with Acme Power Roller Skates
  • Thread starter Thread starter parwana
The discussion revolves around a physics problem involving kinematics, specifically focusing on the motion of Wile E. Coyote as he attempts to reach the edge of a cliff using Acme power roller skates that provide constant horizontal acceleration. The problem includes calculating the time it takes for the coyote to fall from the cliff and the horizontal distance he travels during that fall.
  • Participants discuss breaking the problem into components, calculating the time to fall, and determining horizontal distance traveled. There are questions about the setup and calculations, particularly regarding the initial conditions and the effects of acceleration.
Some participants are exploring different methods to solve the problem, with one suggesting a component-wise approach and another expressing uncertainty about their calculations. There is an acknowledgment of the need to consider initial conditions and horizontal speed, indicating a productive direction in the discussion.
Participants are working under the constraints of the problem as presented, including the assumption that the coyote's acceleration continues during his flight. There is a mention of potential setup errors and the need for clarity on initial velocities.
parwana
The determined Wile E. Coyote is out once more to try to capture the elusive roadrunner. The coyote wears a new pair of Acme power roller skates, which provide a constant horizontal acceleration of 15 m/s2, as shown in Figure P3.73. The coyote starts off at rest 70 m from the edge of a cliff at the instant the roadrunner zips by in the direction of the cliff.
Figure P3.73
(a) If the roadrunner moves with constant speed, find the minimum speed the roadrunner must have in order to reach the cliff before the coyote.
22.9 m/s
(b) If the cliff is 100 m above the base of a canyon, find where the coyote lands in the canyon. (Assume that his skates are still in operation when he is in "flight" and that his horizontal component of acceleration remains constant at 15 m/s2.)
I got part a, but I am not getting part b, please help
yeah Noein I tried it by doing it for each component, but can't get it right
Calculate how long it will take the Coyote to drop through 100m down the cliff. Then use this time to calculate the horizontal distance he will travel during the drop down to the base of the canyon.
I am getting it wrong, maybe I set it up wrong?
squareroot(100/4.9= 4.517 s
then x= .5(15)(4.517)^2
try drawing a picture and writing down what you know. If you are at rest and then start your Vo=0. try filling out a chart of what you know and then looking to see what you need to find, then use the according equation.
Your formula for x do not have the part of his horizontal speed when he left the edge of the cliff. Remember that he accelerated for 70 meters before he got to the edge.
  • · Replies 16 ·
