Calculate Rise Time for Sinusoidal Signal at f_0
The discussion revolves around calculating the rise time for a sinusoidal signal at a specified frequency, f_0. Participants are tasked with expressing this rise time in relation to the signal's period, T, and are exploring the implications of the signal's characteristics, such as its zero average and amplitude definitions.
  • Participants are examining the definition of rise time, particularly in the context of a sinusoidal waveform transitioning from 10% to 90% of its amplitude. They discuss the mathematical relationships involved, including the use of angular frequency and the sine function to determine the time intervals corresponding to specific amplitude thresholds.
There is ongoing exploration of the relationships between frequency, angular frequency, and rise time. Some participants are questioning the clarity of the problem statement regarding the rise time definition, while others are attempting to derive equations based on their interpretations of the waveform behavior.
Participants note that the problem implies certain definitions and parameters that are not explicitly stated, such as the specific amplitude thresholds for measuring rise time. There is also mention of a specific frequency (50 kHz) for which calculations are to be performed, adding a layer of complexity to the discussion.
VinnyCee
Algebraically calculate the Rise Time value for the sinusoidal signal at an arbitrary frequency [itex]f_0[/itex] (expressed in Hz). Assume that the signal has zero average, that is
[tex]V_{min}\,=\,-V_{max}[/tex]
Express the Rise Time in units of the period [itex]T\,=\,\frac{1}{f_0}[/itex].
MY WORK SO FAR:
[tex]\left(V_{min}\,+\,0.9\,V_{ppk}\right)\,-\,\left(V_{min}\,+\,0.1\,V_{ppk}\right)[/tex]
[tex]V_{ppk}\,=\,V_{max}\,-\,V_{min}[/tex]
[tex]RISE\,=\,0.8\,V_{max}\,-\,0.8\,V_{min}[/tex]
[tex]RUN\,=\,T[/tex]
SLOPE equals RISE over RUN, but I don't know how to relate the two things to get an equation for the answer.
The problem goes on to ask us to calculate the Rise Time value in msec for the sinusoidal signal at 500Hz. But I need the equation in order to solve it. Please help!
The rise time of a pulse is the time taken to go from 10% to 90% of its final value.
So given a simple sin wave [itex]sin\omega t[/itex], one wants to find the time that it takes the signal to go from t1 = 0.1 to t2 = 0.9 if the signal goes from 0 - 1, or t1 = -0.8 to t2 = 0.8 if the signal goes from -1 to 1.
Now how to find t?
If one knows the value of the function, e.g. 0.1, then
[itex]sin\omega t\,=\,0.1[/itex], or
[itex]\omega t\,=\,sin^{-1}(0.1)[/itex], or
[tex]t\,=\,\frac{sin^{-1}(0.1)}{\omega}[/tex]
One then needs to know the relationship between [itex]f[/itex] and [itex]\omega[/itex] .
Angular frequency, [itex]\omega[/itex], is equal to [itex]2\,\pi[/itex] times the frequency [itex]f[/itex](in Hertz).
So the Rise Time for a -1 to 1 sinusoidal signal is [tex]T\,=\,\frac{sin^{-1}(-0.8)}{2\,\pi\,f_0}[/tex]? What about the positive one? Should I be subtracting it from the one just stated?
Sorry if I missed it, but the term rise time must be qualified with what fraction of the total waveform amplitude the rise time is measured over.
For example, it is common with trapezoidal logic signals to refer to the "10 to 90 rise time", which means that you measure the time it takes during the rising transition for the signal to go from 10% of the final value to 90% of the final value.
Was something like this mentioned in the original problem statement?
Yes, its exactly what is stated earlier in the lab manual. The problem itself does not specify this though, it is implied.
Does the T equation that I have above look right for the 10 to 90 rise time in terms of [itex]f_0[/itex]?
I'm not sure I understand your approach, but just calculate what fraction of a period it takes for the sine wave to go from zero to 0.8 in amplitude. You'll get something a little less than a radian, I believe. Then multiply by 2 to get the total 10-90 rise time of the sine wave (from -0.8 to + 0.8). Since the answer is in terms of radians at the frequency of any sine wave, that shows that the frequency does not matter.
So the T above is the correct answer?
Using your algebraic results, calculate the Rise Time in [itex]\mu s[/itex] for the sinusoidal signal at 50 kHz.
Please help! I have NO IDEA what the problem is trying to get at. Please help!
  • · Replies 31 ·
