Thread Closed
Correct use of "is proportional to" symbol (alpha)
Share Thread Thread Tools
Sep28-06, 01:50 AM   #1
Hello, I am facing a problem that can be solved quite easily using the proportional symbol ( I think ), so I would like to try to use it! Only problem is.. I don't know exactly how to use it correctly...
The question is :An astronaut weighs 882N on Earth, determing the weight of the astronaut on Planet X, which has a mass 95.3 times that of Earth and a radius 8.9 times that of Earth.
So, [tex]g=\frac{Gm}{r^{2}}[/tex] and thus [tex]g\alpha\frac{m}{r^2}[/tex]
So I wrote down
[tex]g\alpha\frac{95.3}{79.21}[/tex]
But of course this false... g is not proportional to 95.3/79.21.. lol. Can someone show me how to correctly show my work? Thanks. This would allow me to simply use this ratio to calculate his new weight.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep28-06, 02:20 AM   #2
J77
Remember that G is the gravitational constant, ie. it always takes the value 6.67ishe-11
This constant turns the proportionality into an equality.
Sep28-06, 02:56 AM   #3
Recognitions:
Homework Helper Homework Help
Quote by Checkfate
So I wrote down
Saying [itex]g \propto m/r^2[/itex] is equivalent to saying that [itex]g = Gm/r^2[/itex] where G is a constant (the proportionality constant) ie. g is a linear function of m and r2. If you want to perform mathematical operations you have to use the equality sign and the constant.
[tex]g_1 = \frac{GM_1}{r_1^2}[/tex]
[tex]g_2 = \frac{GM_2}{r_2^2}[/tex]
dividing, the constant falls out:
[tex]\frac{g_2}{g_1} = \frac{M_2}{M_1}\frac{r_1^2}{r_2^2}[/tex]
AM
Sep28-06, 04:34 AM   #4
Recognitions:
Quote by Checkfate
So I wrote down
g is proportional to [tex]\frac{m}{r^2}[/tex]
but when cramming in the values you did, you get a comparison to Earth's "g." Multiply (95.3/79.21) by 9.81, and you get the "g" of the other planet.
Sep28-06, 06:57 AM   #5
If you want to use the proportionality sign, then say
[tex]g_{e}\propto \frac{M_e}{r_e^2}[/itex]
and
[tex]g_{x}\propto \frac{M_x}{r_x^2}[/itex]
where [itex]g_{e/x}[/itex] refers to earth or planet x etc. Now you can say:
[tex]\frac{g_x}{g_e}=\frac{M_xr_e^2}{r_x^2M_e^2}[/tex]
[tex]g_x}=g_e\frac{M_xr_e^2}{r_x^2M_e^2}[/tex].
By the way, the "proprtional to" symbol isn't alpha. In tex it's "\propto"... heres the difference:
[tex]\alpha \ldots \propto[/tex]
The first is alpha, the second is proptional to.
Sep28-06, 12:24 PM   #6
Thanks alot guys! :)
Thread Closed
Thread Tools
Similar Threads for: Correct use of "is proportional to" symbol (alpha)
Thread Forum Replies
Alpha Decay "extra" electrons High Energy, Nuclear, Particle Physics 12
Organic element symbol "R" Chemistry 2
math symbol for "in terms of" General Math 4
Is this proof for a "linear differential eq" correct purely mathematically Math & Science Software 2
"Symbol" html on Netscape and Explorer Computing & Technology 5
