How to Find the Maximum Value in This Calculus of Variations Problem?
The discussion revolves around finding the maximum value of the functional A[y(x)] defined as the integral of y^2 with specific boundary conditions and a constraint involving the derivative of y. Participants explore the application of the Euler-Lagrange equations and the method of Lagrange multipliers in the context of calculus of variations.
  • One participant questions whether the Euler-Lagrange equations are appropriate for finding a maximum value, noting they typically find minimum values.
  • Another participant clarifies that the Euler-Lagrange equations can find both maxima and minima, similar to the derivative test in calculus.
  • Several participants discuss the implications of the boundary conditions and the role of the Lagrange multiplier in the problem setup.
  • There is a proposal that the extremum function can be expressed in terms of cosine and sine functions, leading to discussions about the values of constants and the nature of the solutions.
  • Some participants express confusion about the maximum value of the functional and whether it can be determined from the sine function reaching its maximum value.
  • Disagreement arises regarding the nature of the extremum found, with one participant asserting it is a local minimum while another suggests it might be a saddle point.
  • Participants explore the consequences of sign choices in the equations, leading to different forms of solutions and implications for the boundary conditions.
  • There is a discussion about the potential for multiple stationary points based on the parameter n, indicating a more complex solution landscape.
Participants do not reach a consensus on whether the extremum is a maximum or minimum, with multiple competing views on the nature of the solutions and the implications of the boundary conditions. The discussion remains unresolved regarding the maximum value of the functional.
Participants note potential sign errors in the equations and the implications of these errors on the solutions. There is also mention of the need to clarify the role of the Lagrange multiplier and the specific forms of the solutions derived from the Euler-Lagrange equations.
spock0149
I need to find the maximum value of
[tex]A[y(x)]= \int_{0}^{1}y^2 dx[/tex]
with boundary conditions y(0)=y(1)=0 and
[tex]\int_{0}^{1}(\frac{dy}{dx})^2=1[/tex]
Do I have to use the Euler lagrange equations? I thought that found the minimum value??
Any hints on the steps to take would be appreciated.
Euler Lagrange equations find 'extreme' values- either max or min- just like the derivative test in calclulus.
Hmmm. so how does this sound:
[tex]\frac{\partial f}{\partial y} - \frac{\partial}{\partial x}\frac{\partial f}{\partial y_x}=0[/tex]
and we have
[tex]f=y^2[/tex]
so then
[tex]2y-0 = 0[/tex]
So y=0
I don't think this is correct. What is the approach please?
y=0 certainly extremizes (in this case minimizes) the integral of y^2, so that looks right.
Hmmmm, I need to find the maximum value, is there one?
You must use a Lagrange multiplier since you have a constraint problem!
We look at the problem:
[tex]\hat{A}=\int_{0}^{1}y^{2}dx-\lambda(\int_{0}^{1}(\frac{dy}{dx})^{2}dx-1)=\int_{0}^{1}(y^{2}+\lambda((\frac{dy}{dx})^{2}-1))dx,y(0)=y(1)=0, \int_{0}^{1}(\frac{dy}{dx})^{2}dx-1=0[/tex]
where lambda is the Lagrange multiplier.
The associated Euler-Lagrange equation is therefore:
[tex]2y+2\lambda\frac{d^{2}y}{dx^{2}}=0\to{y}(x)=A\cos(\sqrt{\lambda}x)+B\sin(\sqrt{\lambda}x)[/tex]
Using the boundary conditions yields [itex]A=0, \lambda=\pi^{2}[/itex]
whereas a suitable B can be found by the constraint:
[tex]B^{2}\pi^{2}\int_{0}^{1}\cos^{2}({\pi}x)dx=1\to{B}=\pm\frac{\sqrt{2}}{\pi}[/tex]
I have a bad habit of not reading people's question fully before answering. Let me now officially make the resolution to kick this habit. Ok, I feel better now.
Awesome post Arildno.
This really have me somewhere to start and using this I could actually figure out what my math book was (not) explaining to me.
One thing, in your first line you subtract the term containing the lagrange multiplier, and then directly after that you add it.
Was this a mistake or is there something I'm just not getting.
Also, is the maximum value of the function just when Cos(x) goes to 1?
Thanks again.
Just a typo on my part.
I don't get your second question.
Oh ok thanks.
Well, the question asked for the maximum value of the function A[y(x)] and so as we discovered the the function was:
[tex]\frac{\sqrt 2}{\pi}sin(\sqrt\lambda x)[/tex]
so is the maximum value when the sin term goes to 1?
No, first of all:
A(y(x)) is a SCALAR, not a function!
We have, for the extremum function satisfying the given constraint:
[tex]\hat{A}(y)=\frac{\sqrt{2}}{\pi}\int_{0}^{1}\sin^{2}(\pi{x})dx=\frac{1}{\sqrt{2}\pi}[/tex]
Furthermore, it is provable that this represents a local MINIMUM, not a maximum.
Is that because the second derivative of y is positive?
Hold on, If y^2 is sin^2 then the second derivative will be negative won't it?
Thanks for your patience with me.
Actually I want to verify a small sign mistake with you that alters the solution:
The integrand should read:
[tex]g=y^2+\lambda({\frac{\partial y}{\partial x}}^2-1)[/tex]
and the euler lagrange equations are:
[tex]\frac{\partial g}{\partial y}-\frac{d}{dx}{\frac{\partial g}{dy'}}=0[/tex]
Which gives us
[tex]y-\lambda y''=0[/tex]
Which has exponential solutions:
[tex]Ae^{\sqrt{\lambda}x}+Be^{-\sqrt{\lambda}x}[/tex]
Could you possibly verify this?
Thank-you
Well, that's true enough if you use the plus sign, rather than the minus sign. In that case, the solution of the boundary value problem requires imaginary square root of lambda in order to provide a non-zero solution.
The complex exponential is, of course, directly related to the trig. functions.
Thereby, you get the solution I gave you using the minus sign.
Hmmm...am I right in saying that its up to you which sign you give lambda?
I prefer your solution by the way! ;)
Oh, one last thing: You mentioned that:
[tex]\lambda=\pi^2[/tex]
Should this be [tex]\lambda=n^2\pi^2[/tex]
Or can we forget about the n?
No, it isn't. When applying the boundary conditions, the only viable exponential function is a complex choice (imaginary square root of lambda). Just try it!
I have to bit back what I said about the stationary function being a minimum, it is only a saddle point. Sorry about that; I got confused by my own sign mistake..
Ok:
[tex]y=Ae^{\sqrt{\lambda}x}+Be^{-\sqrt{\lambda}x}[/tex]
Applying BC's
[tex]y(0)=0[/tex]
So, A=0
And [tex]y(1)=0[/tex]
So
[tex]0=Be^{-\sqrt \lambda}[/tex]
Writing out as hyperbolic functions:
[tex]B(sinh(-\sqrt\lambda)+cosh(-\sqrt\lambda)=0[/tex]
This gives us:
[tex]-tanh(\sqrt\lambda)=0[/tex]
I'm getting lost now...
You can perfectly well use the n as well, so you have multiple stationary points for this problem, one for each n.
I think we typed our questions at the same time!
Arildno?
Need your advice here buddy!
I've answered that question previously;
The only way(s) to get a non-zero solution in the exponential case is by setting [tex]\lambda^{2}=-n^{2}\pi^{2}[/tex]
Sure, but your solution contained the Cos and Sin term, but then we realized there was a sign error and this gave Sinh and Cosh solutions and
I wanted to confirm with you that this was correct (see post 17 for modified solution).
No, the sign "error" was the plus sign.
I answered this in 14.
Hi Arildno,
Let me show you what I've got so far:
[tex]\hat{A}=\int_{0}^{1}y^{2}dx+\lambda(\int_{0}^{1}(\frac{dy}{dx})^{2}dx-1)=\int_{0}^{1}(y^{2}+\lambda((\frac{dy}{dx})^{2}-1))dx,y(0)=y(1)=0, \int_{0}^{1}(\frac{dy}{dx})^{2}dx-1=0[/tex]
I said I meant to use the minus sign!
How many times must I tell you that.
lol, I am sorry. I was editing the post then got distracted by a phone call.
  • · Replies 20 ·
