Why Do the X Components of the Electric Field Cancel Out?
The discussion revolves around understanding the components of the electric field produced by two charges at a specific point. The original poster expresses confusion about why the x components of the electric field cancel out while the y components do not, despite having calculated the components correctly.
  • Participants explore the symmetry of the electric field components and question the definitions of angles used in the calculations. There is discussion on how the orientation of the angle affects the components of the electric field.
Participants are actively engaging with the problem, offering insights into the symmetry of the electric field and the implications of angle definitions. Some guidance has been provided regarding the interpretation of components, but there is no explicit consensus on the reasoning behind the cancellation of components.
There is mention of a drawing and a problem statement that may have omitted steps, leading to confusion. The discussion also hints at potential differences in angle definitions that could affect the interpretation of the components.
FocusedWolf
I have this standard homework problem to find the electrical field at a point.
I figured out most of the math like the x and y components of the E Field from the two charges acting on the point. I also have the correct answer and i don't understand why the x components of the electrical charge cancel and all that's left is the sum of the two y components.
Here's drawing of problem and me figuring out direction of e fields: http://focusedwolf.googlepages.com/work2.bmp
It just looks to me like the y components should cancel and it's the sum of the x components.
If the charges are equal in magnitude, the y-components should cancel, and the resulting field would be twice the x-component (in magnitude) of the field of anyone charge.
So your agreeing with my intrepration?
Here is the problem... with "work". they skpped a lot of steps, but notices at end says the x components cancel due to symmetry, and not the y. zzz
http://focusedwolf.googlepages.com/problem.jpg
Although not specified, I think they may have defined [tex]\theta[/tex] with respect to the y-axis. In that case, what they've stated is correct. [tex]cos\theta[/tex] components, and not the "x-components", do cancel out due to symmetry.
Hmm i think i get it...so its its not x = Ecos(theta) and y = Esin(theta) but instead, cause theta is "looking down", x = Esin(theta) and y = Ecos(theta)... so the x's do sum and the y's do cancel... just backwards :smile:
So if theta was defined from between x-axis and P, the "normal" way could be used with x = Ecos(theta)... and get same answer?
The answer would be the same, but your new theta would be pi/2 - old theta.
Remember, the direction of the field does NOT depend upon what coordiante system or the angle convention you use. If you're in doubt, think of it in physical terms.
Yep it worked :biggrin:
http://focusedwolf.googlepages.com/answer.jpg
  • · Replies 17 ·
