Speed Average Velocity Change Question
The discussion revolves around calculating average speed and average velocity in physics problems involving motion. The original poster presents two scenarios: one involving a person walking at different speeds and another involving a skydiver. Participants explore the concepts of average speed and velocity, questioning the methods used to calculate them.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of average speed by questioning the method of simply averaging two speeds. They suggest using the relationship of distance traveled divided by time instead. The original poster also raises confusion about applying formulas for the skydiver's fall and the rocket's ascent, particularly regarding time and acceleration.
Some participants have provided guidance on how to approach the calculations for average speed and velocity. There is ongoing exploration of different interpretations of the problems, particularly regarding the application of formulas and the understanding of motion concepts.
The original poster expresses uncertainty about the time and distance traveled in the walking scenario, which affects their ability to calculate average speed. Additionally, there are constraints related to homework rules that may limit the types of assistance sought.
Kildars
This is my first post here, I am going for high college physics, this is my second physics class in my life. (One in high school and this is Physics 100 -- Survey of Physics.)
We do all our homework online, so here's the first one..
A person walks first at a constant speed of 3.40 m/s along a straight line from Point A to Point B and then back along the line from B to A at a constant speed of 5.60 m/s. What is
(a) her average speed over the entire trip?
For average I simply did 3.4+5.6 = 9 Then I did 9/2 (Two different speeds) and I got 4.5.. but for some reason it's showing up wrong on my webassign. Is there something small I'm missing? Any help would be appreciated.
Second Question
A sky diver, with parachute unopened, falls 625 m in 15.0 s. Then she opens her parachute and falls another 358 m in 168 s. What is her average velocity (both magnitude and direction) for the entire fall?
Magnitude
m/s
So for the free fall v = (a)(t) and because a = g in this instance I did v = (9.8)(15.0) = 147 m/s
So for the free fall velocity = 147
The second part is confusing, The parachute is open so a != 9.8 because of the wind drag on the chute, does a = 1/2gt^2? Cause if it does I think I can figure it out.
Thanks for your help in advance.
Your thinking here is incorrect. Despite the temptation, you don't find average speed by adding two speeds and dividing by two (except under special conditions like constant acceleration). An exaggerated example will make the point: Say you travel one mile at a speed of 1 mile per year, then return at a speed of 1,000,000 miles per year. Is your average speed around 500,000 miles per year? No! You spend much more time going slower so your average speed is much slower!
Instead of trying to average the speeds directly, use the relationship: average speed = distance traveled divided by time.
Second Question
Magnitude
m/s
Again, don't get hung up calculating velocities at various points. Use: average speed = distance traveled divided by time.
Ah, that's right because speed = velocity when the direction is the same. I forgot that point, alright let me work it out.
Sweet, I got it.
a = d/t
s = 625m+358/(15+168)
625+358 = 983
15+168 = 183
987/183 = 5.37 == Right Answer.
For this one
I don't know time traveled or distance traveled so how would I go about using savg = dt
Anyone?
Also this question is bringing up problems also:
A rocket rises vertically, from rest, with an acceleration of 2.8 m/s^2 until it runs out of fuel at an altitude of 1300 m. After this point, its acceleration is that of gravity, downward. (Assume that the positive direction is upward.)
(a) What is the velocity of the rocket when it runs out of fuel?
m/s
(b) How long does it take to reach this point?
s
(c) What maximum altitude does the rocket reach?
m
(d) How much time (total) does it take to reach maximum altitude?
s
(e) With what velocity does it strike the earth?
m/s
(f) How long (total) is it in the air?
s
For A
I tried 1300/2.8 -- I got 464, I assumed that meant it took 464s to get to 1300m but v = at and (2.8)(464) = 1300 which obviously cancels them out, then I thought v = deltaX/deltaT deltaX being 1300 and deltaT being 464 and I got 20.31 which is also wrong..
I really want to do good in physics, I understand the formulas I just don't understand how to apply them to certain problems.
Kildars said:
Anyone?
m/s
s
m
s
m/s
s
For A
Regarding B - use the expression for displacement of the rocket to obtain the time it takes to reach 1300 meters. Further on, plug that time into the equation of the velocity of the rocket. You now have the answer to A, too. For the other parts, use the equation of displacement for a free fall - meaning the only acceleration is gravity.
I think what I am most confused on is how to find time? Is the time to 1300m really 464s? Or did I do that wrong?
You got it wrong. The equation of displacement equals x(t) = 1/2*a*t^2 . Plug in the acceleration and height into the equation and solve for t.
That doesn't make sense to me, where do I plug in "height" I see where to plug in acceleration, but t^2 is not height.. unless you meant x(d) as in change in distance..
x(t) means: the height x in the moment t (i.e. the change of distance with respect to time). So, if we write 1600 = 1/2*2.8*t^2, we get the moment t from the equation, which is the moment the rocket reaches the height of 1600 meters.
Well I figured out a and b
A is 85.32
B is 30.47
I got A by doing:
[tex]v^2 = 2(a) \Delta X[/tex]
2a = (2.8)(2) which equals 5.6
(5.6)(1300) = 7280
Square Root(7280) = 85.32
I got B by doing:
85.32 = 0 + (2.8)t
divide by 2.8
You get 30.47
so t = 30.47
so C
m
When it runs out of fuel at 1300m the acceleration becomes -9.8m/s and at that point the velocity is 85.32. So I tried to do:
[tex]v^2 = v_0^2 + 2 a \Delta x[/tex]
0 = 85.32 + 2*-9.8(x)
-85.32 = -19.6(x)
which is 4.35
and 4.32^2 is 18.94 which is incorrect.
So what did I do wrong on C?
Just use [tex]v = v_{0} + at[/tex], i.e. 0 = 85.32 - 9.81 * t , and solve for t to get the time it takes to reach the maximum altitide. Then, plug that time t into [tex]x = x_{0} + v_{0}t + \frac{1}{2}at^2[/tex], i.e. x = 1300 + 85.32*t + 1/2*(-9.81)*t^2 in order to get the maximum height.
Okay, so
-85.32/9.81 = 8.697
So
[tex]x = 1300 + 85.32*8.697 + 1/2*(-9.81)*8.697^2[/tex]
[tex]8.697^2 = 75.642[/tex]
[tex]x = 1300 + 85.32*8.697 + 1/2*(-9.81)*75.642[/tex]
Then 85.32 * 8.697 = 742.028
Then 1/2(-9.81) = -4.905
Then -4.905 * 75.642 = -371.024
So x = 1300 + 742.021 + 371.024
So x = 1670.997 which is the correct answer, thank you.
Kildars said:
Anyone?
m/s
s
m
s
m/s
s
For E.
How would I start E, I know the answers of A, B, C, D.
A: 85.32m/s
B: 30.47s
C: 1670.997m
D: 38.47s
E: ?
m/s
I tried [tex]v^2 = v_0^2 + 2 a \Delta x[/tex]
[tex]v^2=85.32+2(-9.8) \Delta x[/tex]
v^2 = 65.72(1670.997)
v^2 = 109817.922
v = 331.38 m/s
Which is incorrect, since I don't know the time it takes from 1670-0 I can't use [tex]v = v_0 + a t[/tex].
Any help or advice would be appreciated.
At the rocket's highest point what is it's velocity (it's not 85.32 m/s)?
Using v = vi + at
I got v = 85.32 + (-9.8)*(8.7)
v = .06
Is that correct?
Kildars said:
Using v = vi + at
v = .06
Is that correct?
Not quite. What does the rocket do once it reaches it's highest point?
It stops, the velocity is 0. I was sitting in class a realized it, haha. I feel stupid ;).
Anyways, I figured it out it was -180.91 m/s. :)
Thanks for your help I'll probably need help on some other stuff so if I can't figure it out I'll post ;)
One gets used to that feeling, unfortunately my eureka moments usually happen just as I'm falling asleep
Kildars said:
For this one
For some reason this problem is really getting past me, I've tried a couple different things and still can't figure it out. I can't do savg = d divided by time because I know neither.
You don't need to know the distance. Try this: Call the distance from A to B "D". Compute the total time and distance in terms of the speeds and D and see what happens.
I know that is supposed to help me, but I don't understand what that means, How can I use any of the formulas that I know at the moment, with two unknowns? I don't know acceleration, distance, or time.
You have the distance: it's D! :wink: Now use the speed to find the time from A to B, and from B to A. Then find the average speed for the entire trip. Try it!
t = 3.4d
t = 5.6d
so savg = d/t
I still don't understand how this helps me because I have two unknowns.
For one thing, Speed = Distance/Time. So redo your time calculations.
Then find:
(1) Total time
(2) Total distance
Then, finally, calculate the average speed. Ave Speed = Total Distance/Total Time.
Then find:
(1) Total time
(2) Total distance
5.6 = d/t1
3.4 = d/t2
t1 + t2 = ttotal
Again, how do I find time total with two unknowns? I'm sorry if I seem really stupid right now, I just know that I can't find something when I have two unknowns and even though I know distance = "D" "D" is still a variable..
First rule: Do what Doc Al tells you! (Just kidding.)
Find t1. Write it down here:
Find t2. Write it down here:
Add them up. That's the total time. Just do it.
D is the one way distance. What's the round trip distance traveled?
Find t1. Write it down here: 5.6t1 = d
Find t2. Write it down here: 3.4t2 = d
I don't understand how to add them up with two variables, sorry :(.
There's got to be another way.
t1 = d/5.6
t2 = d/3.4
Just do it!
t1 + t2 = d/5.6 + d/3.4 = d(1/5.6 + 1/3.4)
That's the total time. Now what's the total distance (round trip)?
Doc Al said:
t1 = d/5.6
t2 = d/3.4
Just do it!
d = (5.6/d1 + 3.4/d2)
  • · Replies 17 ·
