Propagation of uncertainty calculations
The discussion revolves around calculating the propagation of uncertainty in the charge/mass ratio of an electron, measured using a Helmholtz coil and vacuum tube. The original poster is concerned about the large percent uncertainty resulting from the formula used, particularly due to the constant factor of 2.47E12.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the impact of the large constant on uncertainty calculations and question the formula used for propagation of uncertainties. There are inquiries about the uncertainties associated with each measurement parameter and the potential for mathematical errors.
The discussion is ongoing, with participants providing insights into the nature of the uncertainties involved and suggesting that the original poster clarify the uncertainties of the individual measurements. Some guidance has been offered regarding the assessment of measurement accuracy and the implications of large uncertainties.
Participants note that the number of turns in the coil should have no uncertainty, and there is a focus on the relative sizes of uncertainties for the parameters involved in the calculation. The original poster mentions that all uncertainties are reasonably small, yet the large constant still leads to significant overall uncertainty.
leright
I hope this is the right place for this...
Well, I have a lab where we measured the charge/mass ratio of an electron using a helmholtz coil and vacuum tube. I need to calculate the propagation of uncertainty in my final value. The formula for calculating the e/m ratio is the following...
e/m = (2.47E12(a^2/N^2))*(V/((I^2)*r^2))), where a is the radius of the coil that produces the B-field, N is the number of turns in the coil, V is the electron accelerating voltage, I is the coil current, and r is the radius of curvature of the electron beam.
Now, when I calculate the propagation of uncertainty the factor 2.47E12 makes the uncertainty very large and the percent uncertainty is around 50%. What do I do about that huge number??
Thanks.
anyone have any advice?
The constant 2.47E12 should give large uncertainties since the uncertainties are of small numbers themselves.
What formula are you using for propagation of uncertainties?
well, it does give large uncertainties.
This is the formula I always use...
https://www.physicsforums.com/showthread.php?t=132778
The second formula that is.
Well that is the correct formula.
What are the uncertainties of each of the values? For example, the number of turns in the coil should have no uncertainty. If the uncertainties are on the order of a few percent of 4 parameters, a, V, I and r, then one might get a 50% error, but if the uncertainties are fractions of a percent, then I would suspect a mathematical error.
What is the largest uncertainty? If a single uncertainly is large, then one would have to reduce the uncertainty with a better measurement or better device.
All of the uncertainties are reasonably small, but when you take the derivative of the e/m equation that huge constant is still there...the uncertainties of the measurements are not small enough to balance it out...
