Thread Closed
C program display time
Share Thread Thread Tools
Oct1-06, 02:02 PM   #1
Ok, I have to write a program that displays an arbitary time. I'm given 2 ticks every 1 second. So I'm suppose to use that to display the Hour, minute and seconds...im not sure where to start on how to create this. I know to find seconds I just do ticks/2, but for minutes and hours I'm confused...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Oct1-06, 02:04 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
So your program is given an integer -- represented in ticks -- and you just need to convert ticks into seconds, minutes, hours, etc?
I'd suggest you look into using the / (integer division) and % (modulo) operators.
- Warren
Oct1-06, 02:34 PM   #3
Quote by chroot
- Warren
Yes, that's correct. So if I do the following
seconds=ticks*2
minutes=seconds/60
hours=minutes/60
how do I then use those values to display the correct hours, minutes?
for example I have 3602 seconds, that will be 60.0333333 minutes, and 1.00055556 hours
Oct1-06, 03:30 PM   #4
Recognitions:
You're not understanding me. The best solution uses BOTH the % and / operators.
If you divide 3602 seconds by 3600 seconds (1 hour in seconds) with integer division, the answer will be 1. This is the number of hours.
If you then perform the same divison, but take the remainder (using the % operator), the remainder is 2.
Perform the integer division 2 / 60 (1 minute in seconds). The answer will be 0. This is the number of minutes.
Perform the same division, but keep the remainder (2 % 60), which will be 2. This is the number of seconds.
- Warren
Thread Closed
Thread Tools
Similar Threads for: C program display time
Thread Forum Replies
program to display student number Computing & Technology 0
How to calculate program execution time? Programming & Comp Sci 4
Astro simulation program problem - program bugs? Astrophysics 4
Develop a program to display a number, on a single 7 segment LED display Computing & Technology 6
Display a number, on a single 7 segment LED display Introductory Physics Homework 0
