Show the metric function is continuous
The discussion revolves around demonstrating the continuity of a metric function \( d: X \times X \to \mathbb{R} \) within a metric space \( X \). Participants are exploring the properties of the metric and the implications for open sets in the standard topology on \( \mathbb{R} \).
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to show that the preimage of an open interval under the metric function is open, but expresses uncertainty on how to proceed. Some participants suggest using the properties of open balls and the triangle inequality to establish the necessary conditions for openness.
Participants are actively engaging with the problem, offering hints and guidance on how to approach the proof. There is a recognition of the need to find appropriate open balls and apply the triangle inequality, but no consensus or resolution has been reached yet.
The original poster is working under the assumption of the standard topology on \( \mathbb{R} \) and is exploring the implications of the metric properties without having a complete solution at this stage.
ak416
Let X be a metric space with metric d. Show that d: X x X -> R is continuous.
I know the properties of the metric:
d(x,y) > 0 if x != y, d(x,x) = 0
d(x,y) = d(y,x)
d(x,y) + d(y,z) >= d(x,z)
Now take any open set (a,b) in R (im assuming the standard topology on R). d^-1((a,b)) = {(x,y) e X x X : d(x,y) e (a,b)} (e stands for element)
Now i have to show d^-1((a,b)) is open. I tried playing around with the properties in different cases, but i don't have a clear indication of how to move on from here. I will keep trying but if anyone can guide me that would be good.
The open balls form a basis for the metric space, so to show a set is open, for each point in the set you need to find an open ball about that point that is contained in the set. In this case, use the triangle inequality.
I tried the open balls method, but i can't find one that is a subset of (a,b). Only that its a subset of (0,b). I tried many different inequalities but I am going nowhere...any more hints?
So say a point (x,y) is in the preimage of (a,b). Then the distance between x and y is between a and b. Now you want to find an open ball U around x and V around y such that the distance from any point in U to any point in V is between a and b, because then UxV is a neighborhood of (x,y) contained in the preimage of (a,b). Try drawing this out in R^2 and see where the triangle inequality needs to be applied.
  • · Replies 19 ·
  • · Replies 40 ·
  • · Replies 27 ·
