Average speed between two points
The discussion revolves around the concept of average speed and average velocity, particularly in the context of calculating these values between two points. Participants explore the definitions and implications of these terms in relation to distance and time.
  • Participants question the calculation of average speed and whether it can be zero under certain conditions. There is a discussion about the difference between average speed and average velocity, with attempts to clarify these concepts.
Some participants have provided clarifications regarding the definitions of average speed and average velocity, noting that average speed cannot be zero unless there is no movement. The conversation reflects an exploration of these concepts without reaching a definitive conclusion.
There is an emphasis on understanding the distinction between total distance traveled and the straight-line distance when discussing average speed and average velocity. Participants are navigating through assumptions about movement and directionality.
synx
if i have to find the average speed between two points, do i just subtract distance2 from distance1 and divide by the time interval? so it could be possible for the average speed to be 0 if whatever traveled equally length in both negative and positive direction?
It is impossible for speed to be zero unless the body doesn't move at all. Average speed is the total distance over total time. If a person runs 5 km North and then 5 km South in a total of 1 hr, then the persons average speed is 10 km/hr. In this case, the average velocity is zero.
To calculate average speed, use the total path length traveled by the object between the start and end points, as measured by something like a car's odometer, which follows the twists and turns of the path. To calculate average velocity use the straight-line distance between the start and end points of the path.
No, this statement works only if you substitute "average velocity" for "average speed." The only way the average speed can be zero is if the object remains stationary, i.e. doesn't travel at all.
I understand now, thanks for clearing that up for me.
  • · Replies 40 ·
