Thread Closed
An LDV decomposition of a matrix.
Share Thread Thread Tools
Oct2-06, 03:38 AM   #1
i need to prove that if A is symmetric and invertible (i.e A^-1 exists), and A=LDV, when L is lower triangular matrix with ones on it's diagonal and V is an upper triangualr matrix also with ones on the diagonal and D is a diagonal matrix then V=L^t.
what i did is:
i know that V^t is an LTM and L^t is an UTM, and that D=D^t, but from i havent seucceded in getting V=L^t.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct2-06, 10:50 AM   #2
AKG
Recognitions:
Homework Helper Homework Help
Hint 1: prove that the equation [itex](V^T)^{-1}LD = DL^TV^{-1}[/itex] makes sense, and then that it's true.
Hint 2: If L is lower triangular with 1's on the diagonal, then what of L-1?
Bonus Hint (highlight, only if you're stuck): If X and Y are lower triangular and D is diagonal, what of XYD?
Oct3-06, 05:33 AM   #3
from LDV=V^tDL^t and V^-1D^-1L^-1=(L^T)^-1D^-1(V^T)^-1
(V^T)^-1=DL^TV^-1D^-1L^-1
(V^T)^-1LD=DL^TV^-1.
for the second hint i think that it's also an LTM.
and because V is a UTM V^t is an LTM so we have in the last equation in the lhs that we have product of two LTM which is also an LTM, time D which makes another LTM, which in return equals a product of a UTM, so we must have that V=L^T, is this correct?
Oct3-06, 08:33 PM   #4
AKG
Recognitions:
You need to first show that L and V are invertible, otherwise your equations don't even make sense. Once you've done it, it's somewhat less complicated than what you've done, although what you've done is right:
[tex]LDV=V^tDL^t[/tex]
[tex](V^t)^{-1}LDV = DL^t[/tex]
[tex](V^t)^{-1}LD = DL^tV^{-1}[/tex]
You could even do those last two steps in one. V is a UTM, so VT is an LTM. Can you prove that (VT)-1 is also an LTM? L is an LTM, and so is D, so can you prove that the whole left hand side is an LTM? Likewise, can you prove that the whole right hand side is a UTM? This means that both sides are both LTMs and UTMs, so they're diagonals. But D is a diagonal, so you in fact know that (VT)-1L and LTV-1 are both diagonal. What can you say about the entries on the diagonal? Well you know that L and V have 1's on the diagonal, so you can prove that (VT)-1L and LTV-1 have 1's on the diagonal. In short, these matrices are the same, and they are the identity matrix. But if LTV-1 = I, then of course LT = V, as desired.
Oct4-06, 04:18 AM   #5
L and V are row equivalent to I, so if they are nxn matrices then they rank is n, and thus they are invertible.
Thread Closed
Thread Tools
Similar Threads for: An LDV decomposition of a matrix.
Thread Forum Replies
Help! Diagonal matrix similar to upper triangular matrix? Linear & Abstract Algebra 1
Unitary Matrix to Quantum Circuit Decomposition: Software? General Physics 1
Matrix, making R2 to R3, finding standard matrix A! where did i mess up? Calculus & Beyond Homework 1
Matrix decomposition Linear & Abstract Algebra 0
