Voltage & Batteries: Separating the Charges
The discussion clarifies the concept of voltage using a battery as an example. A battery separates positive and negative charges, creating a difference in electrical potential, which is analogous to gravitational potential. When connected to a load, the electric field generated by this potential difference causes electrons to move through the wire. It is emphasized that while electrons flow in the wire, positive charges remain fixed and only move within the battery's electrolyte.
  • Understanding of basic electrical concepts, including voltage and current.
  • Familiarity with battery operation and charge separation.
  • Knowledge of electric fields and their role in charge movement.
  • Basic grasp of analogies between electrical and gravitational potential.
  • Research the principles of electric fields and their effects on charge movement.
  • Explore the mechanics of battery operation, focusing on ion movement within electrolytes.
  • Study the relationship between voltage, current, and resistance using Ohm's Law.
  • Investigate the differences between conductors and insulators in electrical circuits.
Students of physics, electrical engineers, and anyone interested in understanding the fundamentals of voltage and charge movement in electrical systems.
vg19
Hi, I just would like to make sure that my concepts are clear on voltage. Using a battery as an example, I have a couple of questions...The battery separates the positive charges from the negative charges, which in result causes a separation (voltage). Now, if the battery is connected to a load, the negative charge travels through the wire to the positive terminal, and opposite for the positive charge. Why and how is this voltage or emf moving the charges through the wire to the other termininal?
Electrical potential acts just like gravitational potential. You're familiar with the fact that a ball will roll down a hill, of course -- it's really the same concept for electric phenomena.
A battery creates a difference in electrical potential -- in the same way that a ramp "creates" a difference in gravitational potential -- and electrons "roll down the hill" caused by this difference.
In more specific terminology, the difference in potential at either end of a wire creates an electric field inside the wire, and this electric field causes electrons to move.
Please note that in normal wires, the positive charges are fixed. No positive charges move through the wires. Positive charges (in the form of ions) do indeed move inside the battery, through the electrolyte, but they don't move through the wire.
- Warren
  • · Replies 44 ·
