Does a North Pole Magnetic Field Create AC in a Wire Passing Through?
The discussion centers on the behavior of electric current in a wire subjected to a north pole magnetic field. When a magnet moves in one direction, it induces a voltage in the wire loop. If the magnetic flux changes at a constant rate, the induced voltage remains direct current (DC). However, if the magnetic flux varies over time, such as when a magnet is moved past the loop, the output becomes alternating current (AC). This principle is fundamental in understanding electromagnetic induction.
  • Understanding of electromagnetic induction
  • Familiarity with AC and DC voltage concepts
  • Knowledge of magnetic flux and its effects
  • Basic principles of transformers and their operation
  • Study Faraday's Law of Electromagnetic Induction
  • Learn about the differences between AC and DC generation
  • Explore the operation of transformers and their applications
  • Investigate the effects of magnetic field direction on induced current
Students of physics, electrical engineers, and anyone interested in the principles of electromagnetic induction and its applications in electrical systems.
arevolutionist
I fail to recall this concept. When only a north pole magnetic field is passed along a wire, and then the magnet passes the reversed direction, does the electric current become an AC? The wire never enters the south pole magnetic field.
When the magnetic flux through a wire *loop* changes, that induces a voltage between the ends of the loop. If the flux is changing at a constant rate (like increasing linearly), the coil voltage is DC. If the flux is changing with time (like moving a magnet past a loop, or as in the secondary of a transformer), then the output is AC.
  • · Replies 21 ·
  • · Replies 24 ·
