Statics lever and valve question
The discussion revolves around a statics problem involving a lever and a valve, where participants are tasked with calculating the moment about a specific point (point B) due to a force applied at the opposite end of the lever. The lever is positioned at an angle with respect to the horizontal, and the force is applied at an angle to the lever itself.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of torque exerted by a force on the lever, questioning the use of angles and components in their calculations. There is a focus on resolving the force into its perpendicular and parallel components relative to the lever.
Some participants have provided guidance on the approach to calculating torque, suggesting the use of specific formulas and clarifying the importance of the angles involved. There is an ongoing exploration of whether the original calculations were correct and how to properly interpret the angles in the context of the problem.
Participants are working with a specific setup involving a pneumatic system and a foot valve, with constraints on how the force and angles are defined. There is mention of a diagram that could aid in understanding the problem better.
formulajoe
a lever is resting on a valve. the valve is located 3 in from the end of the lever. the total length of the lever is 9.5 in. a 4 lb force is present at the opposite end of the lever. the force makes a 28 deg angle with the lever. the lever makes a 20 deg angle with the horizontal. I am supposed to find the moment about B, which is the spot where the lever comes in contact with the valve.
the force in the vertical direction is -1.9 and the force in the horizontal direction is -3.5.
i got these by multiplying the magnitude of the force by the cos and sin of the angle. i ended up with an answer of 12.35 lb * in.
is that correct?
is that correct?
I assume you are trying to find the torque exerted by the 4 lb force about point B. A diagram would be helpful.
I presume when you say "vertical" and "horizontal" you really mean perpendicular and parallel to the lever, right? You only need the perpendicular component of the force. If that's what you did, then fine! (Is the torque clockwise or counter-clockwise?)
Another way to look at it:
To find the torque exerted by the 4 lb force about point B you can use T=rFsinθ. r is the distance from B to the point of application of the force (r = 6.5"); F is the force (F = 4 lbs), and θ is the angle between them (θ = 28 or 152). So, I get T = 12.2 lb*in. (I can't specify the direction of the torque, since I don't know how you defined your angle.)
heres a pic. the lever itself makes a 20 deg angle with the horizontal. alpha equals 28 deh. was my answer of 12.35 correct?
Reread my answer. Did you make use of the 20 deg angle in your calculations?
heres the question from the text:
a foot valve for a pneumatic system is hinged at B. knowing that alhpa = 28*. determine the momeny of the 4-lb force about point B by resolving the force into components along ABC and in a direction perpendicular to ABC.
so just doing (4lb)(sin 28) X (6.5 in) is the correct answer?
Yes. Note that (4lbs)x(sin 28) = 1.88 lbs, the component of the force perpendicular to ABC. This is the same thing you found, although you called it (incorrectly) the vertical component. Make sense?
  • · Replies 28 ·
9K
  • · Replies 18 ·
