How High Will Water Reach When Fired at an Angle?
  • Thread starter Thread starter studentmom
The discussion focuses on calculating the height at which a stream of water will strike a building when fired at an angle of 30 degrees with an initial speed of 40.0 m/s from a distance of 50.0 m. The x- and y-components of the velocity are determined to be 34.6 m/s and 20.0 m/s, respectively. The time taken for the water to reach the building is calculated using the horizontal component of velocity, followed by determining the vertical height using the kinematic equation Δy = v_0t + 0.5at², where vertical acceleration is -g. The key to solving the problem lies in understanding the relationship between time, displacement, and velocity components.
  • Understanding of projectile motion principles
  • Knowledge of kinematic equations
  • Ability to decompose vectors into components
  • Familiarity with basic physics concepts such as acceleration due to gravity
  • Study the kinematic equations for projectile motion
  • Learn how to decompose vectors into horizontal and vertical components
  • Explore the concept of time of flight in projectile motion
  • Practice solving similar problems involving angles and initial velocities
Students studying physics, educators teaching projectile motion, and anyone interested in applying kinematic principles to real-world scenarios such as firefighting techniques.
studentmom
The problem states:
A fireman is standing 50.0 m away from a burning building. He directs a stream of water from the fire hose at an angle of 30 degrees above the horizontal. If the initial speed is 40.0 m/s, at what height will the stream of water strike the building?
I understand that the velocity (40.0 m/s) needs to be broken down into its x- and y- components using sin and cos. I imagine that I need to find a time (in seconds) in order to get the vertical height. But I can't seem to figure out the equations to use and when to use them. The x-component of the velocity is 34.6 and the y-component is 20. I know that horizontal acceleration is zero and the vertical acceleration is -g.
Any help you can give is greatly appreciated.
Thanks!
Think about it this way:
You want to find how much time it takes for the water to reach the wall in the x-direction first.
Then, you want to find how high the water goes in that amount of time.
So first, we want to find how much time the water needs to reach the wall in the x-direction. The fireman is standing 50m away from the burning building - now all we need is a velocity in the x-direction to find how long it takes for the water to reach the wall. Hmm. How can we do that?
After that, it's just a matter of finding how high up the wall the water goes. For this, remember that acceleration time-integrated twice gives you [tex]\Delta x = v_0t + \frac{1}{2}at^2[/tex].
Don't think about in terms of formulas at first. Think about "What variables do I need to solve for?" and then the formulas will come naturally.
Thank you for your help... I knew what I needed to get, but I couldn't remember how to get there... I was having trouble with the easiest part, v=displacement/time...
Once again, thank you for your assistance.
  • · Replies 38 ·
