Newtons Law: Determine Friction Forces on a Box at Rest
The discussion revolves around determining friction forces on a box at rest on a ramp inclined at 45 degrees. The box has a mass of 22 kg, with given coefficients of static and kinetic friction. Participants are exploring how to calculate the forces acting on the box to ensure it remains stationary under various applied forces.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss drawing free body diagrams and resolving forces into two directions. Questions are raised about the influence of applied forces on normal force and the direction of frictional force. There is exploration of the relationship between static friction and normal force, and how gravity's components affect the box's stability.
Participants are actively engaging with the problem, attempting to clarify concepts and calculations related to forces acting on the box. Some have provided guidance on how to relate forces using Newton's laws, while others are still grappling with the implications of their calculations and assumptions. There is a mix of correct and incorrect reasoning being explored, with some participants questioning their understanding of the concepts involved.
Participants mention the lack of instructional support and the challenges posed by the textbook's explanations. There is a focus on ensuring that the box remains at rest under various applied forces, with discussions about the effects of perpendicular forces on the normal force and static friction.
quickslant
Sorry people, not sure where I am going wrong, I am just not sure in which direction to take this question. I don't even know where to start.
A box with mass of 22kg is at rest on a ramp inclined at 45 degrees to the horizontal. The coeffecient of friction between the box and ramp are (Static friction = 0.78, Kinetic Friction = 0.65)
a) determine the magnitude of the largest force that can be applied upward, parallel to the ramp, if the box ix to remain at rest
b) determine the magnitude of the smalled force that can be applied onto the top of the box, perpendicular to the ramp, if the box is to remain at rest
for a start maybe u want to try drawing the free body diagram of the object and resolve the forces into 2 direction...
a)
i. Will an applied force parallell to the ramp influence the normal force?
ii. If you apply a "strong" parallell force upwards along the incline, in which direction will the frictional force point? Upwards along the incline or downwards?
i am doing this correspondence course and i don't have a teacher helping me so I am not exactly sure where to take this question. i have drawn the free body diagram and i am trying to resolve it into two direction I am just not sure what formulae i am supposed to be using to solve this question. As far as answering those questions you asked i have no idea that's exactly how its phrased in the book. As i said i have nobody else to ask for help
Try to answer the questions I gave you, they are perfectly clear. Use your head for example.
sorry about that .. i wasnt really paying attention
ai) an applied force will not influence the normal force.. at least i don't think it should
aii) frictional force will point downwards
Correct!
So, according to ai), you should be able to calculate the normal force without knowing what the applied force is. Do so!
As for ii), how is MAXIMAL STATIC FRICTION related to the normal force?
Coeffecient of static friction = Static friction max / force normal ??
Quite so, meaning that Static friction max=?
force normal / coeffecient of static friction.
ok so here is what i have so far.. i calculated the force of gravity. 22 (9.8) then to calculate force norm do i do Fg cos 45?
"force normal / coeffecient of static friction"
TOTALLY WRONG! THINK AGAIN!
Do not insert digits yet, keep the letters!
So, the force of gravity is mg, where m is the mass and g is the acceleration due to gravity.
Furthermore, as you've found out, the normal force N=mgcos(45).
Now, what should you do further?
its sin 45.. ok.. so what i got so far is that force normal = mass (acceleration) sin 45, which = 22 (9.8) sin 45 which = 152.45 N correct?
now.. i take that and its force normal / coeffecient of static friction
which = 152.45 / 0.78 which i equate to equal 194.87 N correct?
THIS IS WRONG!
sorry about that.. Fsmax = coeffecient of statfriction * Normal Force
Yes, that's correct. Given the expression for the normal force in post 11, what is Fsmax?
mgcos 45 * coeffecient Fs
Correct!
Now, set up Newton's 2.law PARALLELL to the incline, knowing that the box is at rest, and that the applied force is called A.
mgcos45 * coeffecient of Fs
Eeh, is this Newton's 2.law of motion??
ok done.. let me take a crack at this one more time :
force normal = mass (acceleration)cos 45, which = 22 (9.8) sin 45 which = 152.45 N correct?
now.. Fsmax = force normal * coeffecient of static friction
which = 152.45 * 0.78 which equals 118.9 N correct? when i did the diagram it only makes sense that the applied force can not exceed the normal force * coeffecient of static friction .. am i headed on the right track?
First of all, STOP PUTTING IN THOSE MEANINGLESS DIGITS YET!
Secondly: The normal force is mgcos(45). That it should be the cosine should be evident since when the inclination angle is 0, then the normal force equals mg, not 0 as would be the case using the sine function.
Thirdly, remember that the force of gravity also has a component along the incline.
Set up Newton's 2.law of motion along the incline!
ok.. the book that i am using is absolutely worthless.. what it very vauge and i don't know how the expect people to teach themselves with it. what it has is a triangular block (wedge like) and it has Mg, Fn, Fsmax, and theta labelled. along the incline we have mgsin0 and that's all it shows
all i get is that Fapp > Fsmax if it is to result in acceleration
What is gravity's component along the incline, knowing that the inclination is (theta), or in this case, 45 degrees?
i am so confused. I am sooo sorry I am just not getting it..
mgsin45?
CORRECT!
Now, before continuing, let us recoup what we know about the forces along the incline:
1. Frictional force Ff: We have found that this equals Ff=(mu)mgcos(45), where (mu) is the coefficient of static friction.
Further, as you have stated, Ff works downwards along the incline.
2. Gravity's component: mgsin(45), this also works downwards along the incline.
3. Applied force A: This works UPWARDS along the incline as given in the exercise.
Now, relate these quantities together in Newton's 2.law along the incline, knowing that the box is at rest!
ok.. so this is what my paper looks like
Fapp or A must not exceed ((mu)mg cos45 + mg sin 45) or the box will no longer be at rest according to Newtons 2nd law. am i in the right direction?
That is correct!
And you're finished with a) now..:smile:
(OR, now you can put in the numbers if you like..)
oh thank god.. now where do i start with b.. and again i thank you soooo much you don't know what this means to me!
Okay, about b).
Before doing any maths at all, WHY would the box start sliding if you applied a too strong perpendicular force on it?
