| Thread Closed |
what is the square root of i^2 |
Share Thread | Thread Tools |
| Oct4-06, 08:04 AM | #1 |
what does [tex]\sqrt{i^2}[/tex] equal to? is [tex]\sqrt{i^2} = i[/tex] or [tex]\sqrt{i^2} = \pm i[/tex]?
| Oct4-06, 08:11 AM | #2 |
im guessing its plus&minus
| Oct4-06, 08:14 AM | #3 |
Recognitions:
The square root is usually taken to be the principal branch of the function. I.e. the root whose argument lies in [0,pi), so you would conventionally obtain i.
In general the n'th root of a complex number is taken to be the principal root unless otherwise stated: the root with argument in the interval [0,2pi/n) |
| Oct4-06, 08:24 AM | #4 |
I gave you the usual definition of the square root function in your other thread. You can use that to figure out what it is.
| Oct5-06, 04:32 AM | #5 |
if [tex]z = -1 = -1 + 0.i[/tex], then x = -1, y = 0. [tex]r = \sqrt{\left(-1\right)^2} = \sqrt{1} = 1[/tex] [tex]\theta = \tan^{-1}\left( {0} \over {-1} \right) = 0[/tex] [tex]\sqrt{z} = \sqrt{-1} = \sqrt{r}e^{i\frac{\theta}{2}} = \sqrt{1}e^{0} = 1[/tex] but where did i go wrong? |
| Oct5-06, 04:55 AM | #6 |
Recognitions:
Because arctan only returns values in the region -pi/2 to pi/2, so it is wrong to say that theta is arctan(y/x) alone. You must also use your common sense to see that the argument is actually pi, not zero. It is correct to say that tan(theta)=y/x, but that is *not* the same as theta =arctan(y/x) at all.
| Oct5-06, 05:10 AM | #7 |
yeah, i can see that [tex]\theta = \pi[/tex] from the position of z = -1 in the argand plane. so,
[tex]\sqrt{z} = \sqrt{-1} = \sqrt{r}e^{i\frac{\theta}{2}} = \sqrt{1}e^{i\frac{\pi}{2}} = 1.(\cos{\frac{\pi}{2}} + i.\sin{\frac{\pi}{2}}) = i[/tex] am i right? |
| Oct7-06, 11:30 PM | #8 |
This is my assumption: [tex]\sqrt{i^{2}} = \sqrt{-1} = i[/tex] [tex]i^{2}[/tex] is equal to -1 and square root of -1 is defined as i. |
| Oct8-06, 01:17 PM | #9 |
[tex]\sin{\theta} = \frac{y}{r}[/tex] and [tex]\cos{\theta} = \frac{x}{r}[/tex] simultaneously (taking [itex]\arctan (y/x)[/itex] makes the possible solutions obvious though!). |
| Thread Closed |
| Thread Tools | |
Similar Threads for: what is the square root of i^2
| What is: Square root cut? | General Physics | 10 | ||
| square root | Calculus & Beyond Homework | 4 | ||
| Square root | General Math | 13 | ||
| Square Root | Calculus | 4 | ||
| Square root of pi | General Math | 23 | ||
