Smallest Argument of Complex Number z |z+8i|=4
  • Thread starter Thread starter kishtik
    Argument
The smallest argument of the complex number z satisfying the equation |z + 8i| = 4 is 240 degrees. This is derived from the geometric interpretation of the equation, which represents a circle centered at -8i with a radius of 4. The argument is calculated by determining the angle formed by the tangent line from the origin to the circle, resulting in the angle from the negative imaginary axis being 30 degrees, leading to the final argument of 240 degrees.
  • Understanding of complex numbers and their representation in the complex plane
  • Knowledge of trigonometric functions and their applications in geometry
  • Familiarity with the concept of arguments of complex numbers
  • Ability to solve equations involving square roots and geometric interpretations
  • Study the geometric interpretation of complex numbers in the Argand plane
  • Learn about the properties of complex number arguments and their calculations
  • Explore the relationship between complex numbers and trigonometric functions
  • Investigate methods for solving complex equations geometrically
Mathematicians, students studying complex analysis, educators teaching complex numbers, and anyone interested in geometric interpretations of mathematical concepts.
kishtik
What is the argument of the complex number z which has the smallest argument in |z+8i|=4?
I solved the problem correctly but my answer is rather long
|z-(-8i)|=4 (drawing)
z_0=a+bi, z_1=-a+bi
|a+bi+8i|=4
sqrt(a^2+(b+8)^2)=4 (radius)
a^2+b^2+16b+64=16 (eq 1)
And from 4-8-sqrt(48) triangle
sqrt(a^2+b^2)=sqrt(48)
a^2+b^2=48 (eq 2)
Place into eq 1
48+16b+64=16
16b=-96
b=-6
Placing into eq 2
a^2+36=48
a^2=12
a=+-sqrt(12)
z_0=sqrt(12)-6i
z_1=-sqrt(12)-6i
From the drawing, the smallest argument is at the third zone.
tan theta=-6/-sqrt(12)
=sqrt(3)
so theta=240 degrees.
There must be a shorter solution, can you please help me?
Saying that |z+8i|= 4 is the same as saying (geometrically, in the complex plane) that the distance from z to -8i is 4. That is all z satisfying that are on a circle with center at -8i and radius 4.
The argument of a complex number is the angle the line from 0 to the number makes with the real axis. In this case it is geometrically clear that that will happen when the line from 0 to the circle is tangent to the circle (in the first quadrant). That tangent line, the line from 0 to -8i and the line from -8i to the point on the circle make a right triangle with hypotenuse of length 8 and one leg of length 4. (edited: I just realized that the problem only asks for the argument, not for the actual number itself.)
The angle from the (negative) imaginary axis is given by sin(φ)= 4/8= 1/2 and so φ= 30 degrees. The argument is 270- 30= 240 degrees just as you got.
Knew these.
BLAAAAH! 4*2=8 I should have seen that!
  • · Replies 17 ·
