Solving Wavelength Frequency: 740nm Light
  • Thread starter Thread starter konartist
    Wavelength
The discussion focuses on calculating the frequency of 740nm light using the speed of light equation c=(x)(v). The correct conversion of 740nm to meters is 7.4 x 10^-7 m. The user initially struggles with unit cancellation and the interpretation of frequency, which is defined as the number of wave crests passing a point per second, measured in Hertz (Hz). The final calculation confirms that frequency (v) is derived as 4.05 x 10^14 Hz.
  • Understanding of the speed of light equation c=(x)(v)
  • Knowledge of unit conversion from nanometers to meters
  • Familiarity with the concept of frequency and its unit Hertz (Hz)
  • Basic algebra for manipulating equations
  • Research the relationship between wavelength and frequency in electromagnetic waves
  • Learn about the implications of frequency in various applications, such as telecommunications
  • Explore the concept of wave-particle duality in quantum mechanics
  • Study the effects of wavelength on the behavior of light in different mediums
Students in physics, optical engineers, and anyone interested in understanding the properties of light and its applications in technology.
konartist
The speed of light is 3.0 x 10^8 m/s, given the equation c=(x)(v) where v has the unit of s^-1 what is the frequency (v) for the wavelength (x) of 740nm light?
For some reason I'm not getting the right units; maybe someone can find my mistake:
3.0 x 10^8 m/s = 740nm(v)
740nm x (1m / 10^9) = 7.4x10^-7 m
3.0 x 10^8m/s = 7.4 x 10^-7 m /7.4 x 10^-7
(3.0 x 10^8m/s) / (7.4 x 10^-7m) = V
I seem to be having a problem with my units. Can you have m/s/m ?
What exactly does it mean v has the unit of s^-1 ??
Anyone explain?
No need to put nm there. You've already substituted the value for the 'nano' part.
That seems to be right.
In a sense, the m's cancel, which leaves you with 1/s.
v is the frequency of light. In simple terms, it tells you how many wave crests (or troughs) pass a point in a second. It's a number divided by time. Since numbers are not physical quantities with units, you are left with 1/s. There's a name for 1/s; it's know as Hertz, abbreviated Hz.
