Can Someone Provide Problems from Goldstein's Classical Mechanics (3rd Edition)?
  • Thread starter Thread starter dicerandom
    Goldstein
This discussion centers on the request for specific problems from "Goldstein's Classical Mechanics" (3rd Edition), specifically problems 2.4, 2.6, and 2.9. The user faced issues with their online order and sought assistance due to an impending assignment deadline. The problems involve advanced concepts such as geodesics on spherical surfaces, the Euler-Lagrange equation for the brachistochrone curve, and the minimization of surface area in relation to a chain over pulleys. The community member provided the correct problem numbers and descriptions, confirming their relevance to the user's needs.
  • Understanding of classical mechanics principles
  • Familiarity with the Euler-Lagrange equation
  • Knowledge of geodesics and their properties
  • Concept of minimum surfaces in calculus of variations
  • Study the Euler-Lagrange equation in detail
  • Research geodesics on spherical surfaces
  • Explore the brachistochrone problem and its applications
  • Investigate the calculus of variations and minimum surface problems
Students of classical mechanics, physics educators, and anyone preparing for assignments related to advanced mechanics topics will benefit from this discussion.
dicerandom
Hi All,
I'm hoping that someone will be kind enough to grab their copy of Goldstein's Classical Mechanics (3rd edition) and write out the text of problems 2.4, 2.6, and 2.9 for me.
I ordered the book online a month ago but half.com screwed up my order and I still haven't gotten the textbook :mad: I canceled my order there, got a refund, and ordered the book from a different site so it should be here by Tuesday. Unfortunately my assignment is due Monday and the library on campus only has the 2nd edition, where the problems are quite different
So yeah, any help would be greatly appreciated :)
The exercises are numerated different in my book, so I assumed it's chapter 2, and exercises 4, 6 and 9. So, here they go:
4. Show that the geodesics of a spherical surface are great circles, i.e., circles whose centers lie at the center of the sphere.
6. Find the Euler-Lagrange equation describing the brachistochrone curve for a particle moving inside a spherical Earth of uniform mass density. Obtain a first integral for this differential equation by analogy to the Jacobi integral h. With the help of this integral, show that the desired curve is a hypocycloid (the curve described by a point on a circle rolling on the inside of a larger circle). Obtain an expression for the time of travel along the brachistochrone between two points on Earth's surface. How long would it take to go from New York to Los Angeles (assumed to be 4800 km apart on the surface) along a brachistochrone tunnel (assuming no friction) and how far below the surface would the deepest point of the tunnel be?
9. A chain or rope of indefinite length passes freely over pulleys at heights y1 and y2 above the plane surface of Earth, with a horizontal distance x2 - x1 between them. If the chain or rope has a uniform linear mass density, show that the problem of finding the curve assumed between the pulleys is identical with that of the problem of minimum surface of revolution.
You're lucky I'm bored. :biggrin:
Judging from my notes and discussion in class those definitely look like the right problems.
Thanks a lot :biggrin:
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 20 ·
21K
