Troubleshooting Newton's 2nd Law: Solving for Stopping Distance and Time
The discussion revolves around a physics problem involving Newton's second law, specifically focusing on a loaded dump truck's stopping distance and time under braking conditions. The original poster presents a scenario with given mass and braking force, seeking assistance in calculating maximum negative acceleration, minimum stopping time, and minimum stopping distance.
  • Participants discuss the application of Newton's second law, questioning the unbalanced forces acting on the truck as it brakes. There are attempts to clarify the significance of the truck's initial velocity of 85 km/h and how to convert it for calculations. Some participants suggest using formulas related to acceleration and kinematics to derive the necessary values.
The discussion is active, with participants providing insights into the problem and suggesting methods for approaching the calculations. There is a focus on understanding the role of the initial velocity and the application of relevant equations. While some methods have been attempted, there is no explicit consensus on the final approach or solution.
Participants note the need to convert units for the initial velocity and clarify the definitions of terms used in the problem. There is an emphasis on ensuring that all necessary information is correctly interpreted and applied in the calculations.
soulja101
I really need help with this question. I've tried solving it but i just can't do it.
The question
A loaded dump-truck having a total mass of 2.4*10power of 4 kg is traveling east at 85km/h.The truck driver can apply a braking force of 5.5*10 power of 4 to the wheels without causing the wheels to lock and skid. Calulate:
A)the maxium negative acceleration of this trunk.(in m/s2)
B)the minimum stopping time
C)the minimum stopping distance
The only thing I know is the mass. I know you are supposed to use the 85km/h for something I can not figure out for what.
Thanks
A) Newtons 2nd Law. What is it? As the truck brakes, what is the only unbalanced force on it?
what is 85km/h
what does 85km/h stand for and what do I use it for
85 kilometers per hour, I'd venture.
- Warren
That's your initial velocity and you have to do something with the units. Refer to the link Astronuc put up for the constant acceleration equations.
Thanks
Thanks so much for the help i tried your methods and they seem to work.
  • · Replies 39 ·
