Synchronizing Shed Clocks w/Leading Clock Lag: Explained
  • Thread starter Thread starter Kawaii
    Clocks
The discussion focuses on the synchronization of two clocks attached to a moving shed, specifically addressing the rod and shed problem in the context of the Special Theory of Relativity. When the rod moves with velocity v towards the shed, the leading clock is observed to lag behind the trailing clock by a time difference of l0v/c², where l0 is the stationary length of the shed. This phenomenon occurs due to the relativity of simultaneity, as photons emitted from the center of the shed reach the clocks at different times from the rod's frame of reference. The mathematical derivation confirms that the time difference is influenced by Lorentz contraction and the effects of moving clocks running slow.
  • Understanding of Special Theory of Relativity
  • Familiarity with Lorentz contraction
  • Knowledge of the concept of simultaneity in different frames of reference
  • Basic proficiency in algebra and physics equations
  • Study the implications of the relativity of simultaneity in different inertial frames
  • Explore Lorentz transformations and their applications in physics
  • Learn about the concept of time dilation and its mathematical representation
  • Investigate practical examples of synchronization issues in moving systems
Physics students, educators, and anyone interested in understanding the implications of the Special Theory of Relativity, particularly in the context of time synchronization in moving reference frames.
Kawaii
This is rod and shed problem (rod is moving with v towards shed)
Length of rod measured when the rod is stationary = L0
Length of shed measured when the shed is stationary l0 = 0.5 L0
Two clocks are fixedd to the front and back of the shed. Explain how these clocks may be synchronised.
I did this. (Emitting two photons from the middle of the shed. Triggering the clocks at the back and front of the shed simultaneously)
According to the Special Theory of Relativity, observers stationary relative to the rod judge that the two shed-based clocks are not synchronised, but that in fact the leading clock lags the trailing clock by the amount l0v/c^2. Explain qualitative why this should be so.
I can explain this quantitatively.
Here is my answer. The colcks fixed to the front and back of the shed are synchronised in the shed's frame of reference but from the rod's frame of reference shed is moving which result in observers from the rod's f.o.r (frame of reference) seeing the photon going in the direction of motion of the shed arrive later to one clock (say clock at the front of shed) then the photon going in the different direction of motion arrive to the other clock (say clock at the back of shed). So the clock at the back is triggered before the clock at the front which result in time difference between two clocks and therefore them being not synchronised anymore. The amount of time lag by the front clock is l0v/c^2
let say point f is front of shed, point b is back of shed, and point m is the middle of the shed. Shed's velocity is v.
clock f is at f, clock b is at b. f and b are moving along x-axis with speed v, so fm = mb = l0/2Gamma, being shortened by lorentz contraction.
tf = time at front clock
tb = time at back clock
c = speed of light
ctf = l0/2Gamma + vtf
ctb = l0/2Gamma - vtb
time difference = tf - tb = l0 / (2Gamma*(c-v))
but moving clocks run slow so actual time difference is (tf-tb) divided by Gamma which is l0v/c^2
(I skipped some algebra here for simplicity)
So the question from me is that. I don't know how to say it qualitatively. I can prove it by using Maths. So please anybody help me :(
Thanks,
H
ps. Apologies for wrong spellings and bad grammar.
The first paragraph in your explanation is the qualitative reasoning. You simply and conceptually explain why it is that the front clock should lag the trailing one. The fact that you then go on and quantitatively derive the [itex]l_0 v / c^2[/itex] relationship is extra credit as far as I'm concerned :)
  • · Replies 67 ·
  • · Replies 20 ·
  • · Replies 84 ·
  • · Replies 54 ·
  • · Replies 25 ·
