Ball moving down roof - kinematics
  • Thread starter Thread starter bluevirgo80
    Ball Kinematics
A ball rolls off a roof inclined at 30 degrees with an initial speed of 5 m/s and falls a vertical distance of 7 m. The time the ball is in the air is calculated to be 1.2 seconds, while the horizontal distance from the base of the house is estimated at 6 meters. However, if the ball rolls off horizontally, the time in the air is 0.9 seconds, and the horizontal distance would be approximately 4 meters. The final speed just before landing can be determined using the kinematic equation v = u + at, considering both vertical and horizontal components of motion.
  • Understanding of basic kinematics principles
  • Familiarity with projectile motion equations
  • Knowledge of vector components in physics
  • Ability to apply gravitational acceleration (g = 9.81 m/s²)
  • Study projectile motion and its equations in detail
  • Learn about vector decomposition in physics
  • Explore kinematic equations for vertical and horizontal motion
  • Practice problems involving inclined planes and projectile trajectories
Students studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion and its applications in real-world scenarios.
bluevirgo80
A ball rolls down a roof that makes an angle of 30 degrees to the horizontal. It rolls off the edge with a speed of 5m/s. The distance to the ground from that point is two stories or 7m. (a.) How long is the ball in the air? (b) How far from the base of the house does it land? (c) What is its speed just before landing?
I figured (a) is 1.2s and (b) is 6 meters (hopefully I'm correct) how do I figure out (c)?
Thanks!
Thanks!
Does the roof have a smooth, horizontal surface before it 'rolls off'? I ask because your calculation is not considering the downwards component of the velocity after it has left the roof. If the ball does not roll off horizontally, then I believe the answer is 0.9s. However, if it does roll of horizontally, then you are correct.
If I am correct in assuming you have to consider the angle of the roof then I also think part (b) is incorrect and should be about 4.00 metres from the base fo the house. Again, if I am not correct in assuming the slope matters and that the ball rolls off horizontally, then you are correct again.
The last one, again, is due to components. You know that v = u + at and by setting a = g (or -g depending on your direction) then you just plug in your value for the time and the initial velocity (u) and you have v just before it lands. Again, I reckon it will be the vector due to two components.
I hope that helps a little.
The Bob (2004 ©)
  • · Replies 31 ·
  • · Replies 38 ·
  • · Replies 32 ·
