Find the rest mass M. of the composite particle
The discussion revolves around a problem in relativistic physics concerning the rest mass of a composite particle formed by the collision of two particles, one with a rest mass of m and kinetic energy of 2m.c², and another stationary particle with a rest mass of 2m. The participants explore the implications of conservation laws in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of conservation of energy and momentum in the context of the problem. There are references to the Einstein equation and the need to consider the initial and final energies of the system. Some participants question the interpretation of the energy equations and the correct approach to find the momentum.
The discussion includes various interpretations of the problem and the application of relevant equations. Some participants provide guidance on how to approach the problem, while others express confusion or seek clarification on specific points. There is no explicit consensus on the method to solve the problem, and multiple lines of reasoning are being explored.
Participants note the importance of correctly applying the conservation laws and the Einstein equation, while also addressing potential misinterpretations of these concepts. The original poster's approach and the validity of the provided answer are under scrutiny.
byerly100
A particle of rest mass m. and kinetic energy 2m.c^2 strikes and sticks to a stationary particle of rest mass 2m.. Find the rest mass M. of the composite particle. (.=zero subscript)
The answer is (17)^1/2(m.)
Do you know the formula for addition of speed ? The speed in S is the speed in S' "plus" the speed of S' (where the "" around "plus" refers to the law of speed "addition" that is not as simple as the "+" operation in galilean relativity)
Yeah, except this as seen in S' of an object moving in S at speed ux. To find the inverse formula, just change all the velocities signs:
[tex]u_x = \frac{u_x'+v}{1+\frac{vu_x'}{c}}[/tex]
You know v and you know ux'. Plug and chug away!
byerly100 said:
Also:
This a "conservation law" question. You know that the total energy is conserved and that the total momentum is conserved.
tip: use Einstein equation E²=(pc)²+(mc²)² to find the momentum instead of toying with the gammas to retrieve v.
Since you destroyed the OP, I'm guessing you're no longer interested in getting help.
Write what the initial energy is:
[itex]E_i[/itex] = sum of rest energy of all particles + sum of kinetic energy of all particle. You have all the ingredients in the question to write this out.
After the particles have stuck together and form one chunck of matter of mass M_0, the total energy is
[tex]E_f^2 = p_f^2c^2+M_0^2c^4[/tex]
But by conservation of energy, you know that [itex]E_f[/itex] must equal [itex]E_i[/itex]. So you can combine the two equations of energy to find one equation in two unknowns: M_0 and p_f. All you need to know then, is to find p_i, since by conservation of momentum, p_f must equal p_i.
Not me. Show me how you got that answer.
The equation E²=(pc)²+(mc²)² works for one particle only. It says that the energy of a particle of mass m and momentum p is [itex]\sqrt{(pc)^2+(mc^2)^2}[/itex]. It does not say that the energy of a system of two particles is [itex]\sqrt{(p_1c+p_2c)^2+(m_1c^2+m_2c^2)^2}[/itex]. If you want the energy of a system of two particles, you got to add the individual energies of each particles: [itex]E_1+E_2=\sqrt{(p_1c)^2+(m_1c^2)^2}+\sqrt{(p_2c)^2+(m_2c^2)^2}[/itex].
But for this problem, you only need to use E²=(pc)²+(mc²)².
I explained how you misinterpreted the Einstein equation and how it should be interpreted, namlely, that E²=(pc)²+(mc²)² related the energy of one particle to its momentum and mass. In your problem, there is only one particle that has a momentum (the other is at rest), so you only need to apply E²=(pc)²+(mc²)² on the particle that has a momentum and solve for p.
Why are you deleting your posts? Suppose what I'm telling you is wrong and you're right. Then no one can follow the unfolding of our discussion to point out that I'm wrong and you're right.
I got the answer.
  • · Replies 46 ·
  • · Replies 19 ·
  • · Replies 19 ·
