Find the work contributed by each force
  • Thread starter Thread starter vu10758
    Force Work
The discussion focuses on calculating the work contributed by different forces acting on a pendulum, specifically tension, air resistance, and gravity. It concludes that the work done by tension is zero due to its perpendicular nature to the motion, while air resistance contributes negatively as it opposes motion. The work done by gravity is positive when the pendulum moves from A to B and negative from B to C, based on the angle between the force and displacement vectors. This is explained using the relationship between power and work, derived from Newton's second law.
  • Understanding of Newton's second law of motion
  • Familiarity with concepts of work and energy
  • Knowledge of vector angles and trigonometric functions
  • Basic principles of pendulum motion
  • Study the relationship between work and kinetic energy in physics
  • Learn about the effects of different forces on pendulum motion
  • Explore the concept of power as the time derivative of work
  • Investigate the role of angles in vector calculations for forces
Physics students, educators, and anyone interested in understanding the dynamics of forces acting on pendulums and related mechanical systems.
vu10758
This problem comes with a diagram so I have it at this link
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=21023924&imageID=1274314408
It is problem number 3. I think that the work contributed by tension is zero since the force of tension is perpendicular to the motion of the pendulum in this case. Air resistance is negative since it is acting against the motion. What is the work contributed by the force of gravity. The answer key says that it is positive for part a and negative for part b, but why?
It is easiest to understand this by remembering "power" as the time derivative of work, and rewrite Newton's 2.law to reflect that.
(this is done by multiplyting N2law with the velocity)
Then we get the equation:
[tex]\frac{dW}{dt}=\frac{dK.E}{dt}, K.E=\frac{m}{2}\vec{v}^{2}[/tex]
That is, when you start out with zero work done, and increase it (getting positive), then you INCREASE the kinetic energy of your object!
Relate this to the answers for gravity on b) and c)
Work = |Force| * |Distance| * Cos(angle between them)
in A-B the angle between the distance and force vectors goes from 0-90, and cos is always positive between 0-90. From B-C the angle goes from 90-180, and the cos is always negative from 90-180.
17K
