Temperature Gradient Questions
The discussion focuses on calculating the temperature gradient of the function T(x,y,z) = 2xy - yz at the point P(1,-1,1) and determining the rate of change of temperature experienced by a moving particle in a defined region. The gradient was computed as ∇f = -2i + j + k. The participants explored the directional derivative in the context of a specific direction A and applied the chain rule to find the rate of temperature change for a particle moving along the path defined by x=2t², y=3t, z=-t². The calculations confirmed the temperature change rates at point P(8,6,-4) in both ºC/m and ºC/sec.
  • Understanding of vector calculus, specifically gradient and directional derivatives.
  • Familiarity with the chain rule in multivariable calculus.
  • Knowledge of temperature functions in three-dimensional space.
  • Basic skills in solving equations involving multiple variables.
  • Study the concept of directional derivatives in vector calculus.
  • Learn how to apply the chain rule in multivariable functions.
  • Explore temperature gradient applications in physics and engineering.
  • Investigate the implications of temperature changes in moving particles in thermodynamics.
Students and professionals in mathematics, physics, and engineering who are interested in understanding temperature gradients and their applications in dynamic systems.
Mindscrape
Is there a direction A in which the rate of change of the temperature function [tex]T(x,y,x)=2xy - yz[/tex] at P(1,-1,1) is -3ºC/ft? Give reasons for your answer.
For this problem I found the gradient of at the point P. So
[tex]\nabla f = 2y|_p \mathbf{i} + 2x-z|_p \mathbf{j} - y|_p \mathbf{k}[/tex]
which I then found was
[tex]\nabla f = -2 \mathbf{i} + 1 \mathbf{j} + 1 \mathbf{k}[/tex]
Then we want to know if the gradient, in the direction of A will be 3ºC, so
[tex]\nabla f \cdot \frac{A}{|A|} = \frac{3º}{ft}[/tex]
which means that we want an x, y, z, such that
[tex]\frac{-2x +y +z}{\sqrt{x^2 + y^2 + z^2}} = \frac{3º}{ft}[/tex]
So I believe this is right so far, but I don't think this eqn can be solved for.
Here is the other one:
The Celsius temperature in a region in space is given by [tex]T(x,y,z) = 2x^2 -xyz[/tex]. A particle is moving in this region and its position at time t is given by [tex]x=2t^2[/tex], [tex]y=3t[/tex], [tex]z=-t^2[/tex], where time is measured in seconds and distanace in meters.
a) How fast is the temp experienced by the particle changing in ºC/m when the particle is at the point P(8,6,-4)?
b) How fast is the temp experienced by the particle changing in ºC/sec at P?
So, using the chain rule
[tex]\frac{dT}{dt} = (4x-yz)4t \mathbf{i} - (xz)3 \mathbf{j} + (xy)2t \mathbf{k}[/tex]
For the change per meter I will just solve for one of the t eqns, and then substitute back into the equation to find the gradient?
Then for the change per second, it will be the opposite?
Nevermind, I figured them out.
