Why Can't We Use Normal Alcohols for Vehicle Fuel?
  • Thread starter Thread starter banerjeerupak
The discussion revolves around the feasibility of using normal alcohols, such as ethanol and methanol, as vehicle fuels. Participants explore various aspects including economic viability, energy density, infrastructure challenges, and safety concerns, as well as comparisons to other fuel sources.
  • Some participants suggest that cost and availability are significant barriers to using alcohols as fuels.
  • Others argue that while methanol can be used in vehicles, safety issues arise due to its invisible flames in case of fire.
  • Concerns are raised about the energy density of alcohols compared to gasoline and diesel, with participants noting that vehicles running on alcohols may experience worse gas mileage.
  • One participant mentions that converting all unused land in the U.S. to corn production could only meet a fraction of fuel needs, indicating limitations in agricultural capacity for alcohol production.
  • There is a discussion about the potential for hybrid cars and why alcohol is not being pursued as aggressively as other alternatives.
  • Some participants highlight that taxation and politics may play a larger role in fuel prices than production costs.
  • Hydrogen is mentioned as a potential future fuel source, with discussions about its production from renewable sources and existing infrastructure modifications.
Participants generally agree that there are significant challenges to using alcohols as fuels, particularly regarding land use and energy density. However, there is no consensus on the feasibility of an alcohol-based economy or the potential for hybrid vehicles utilizing alcohol fuels.
Limitations include unresolved questions about the exact energy content of various fuels, the processing costs associated with alternative fuels, and the reliability of certain claims made by participants regarding agricultural yields and fuel production capabilities.
banerjeerupak
Why can we not use normal alcohols such as ethanol or methanol for the purpose of running our vehicles?
is there any particular problem?
what do you mean by cost and availibility.
its cheaper to produce alcohol from sugar and other waste products. methanol is hell cheaper than oil
I don't know about ethanol, but there's no physical reason not to use methanol. Lots of vehicles run on it already, including high-power racers, and even 25 years ago Mohawk gasoline was blended with it. I had to use that in my Roadrunner to boost the octane level. There would be engine tuning modifications needed for the pure stuff.
One potential problem is a safety issue. Alcohol burns with invisible flames, so passengers and rescue workers wouldn't know if there was a vehicle fire in the event of a crash or a fuel spill at a filling station. Maybe an additive would cure that.
Of course the first big reason is infrastructure. We just don't have the capability to make enough alcohol for everyone right now.
The next big reason is the chemical energy stored in them. Because gasoline has excellent energy density (as does diesel), vehicles running off of alcohols will get worse gas mileage. biodiesel's energy content is also lower than petro-diesel, which accounts for why diesels trucks running off of biodiesel get worse mileage; however, the drop is less significant than gasoline to ethanol, and biodiesel has a much higher content than alcohol. Hydrogen is an even worse option in terms of combustion, because it only contains about 12 kilojoules per liter at STP, far less than any of the other options.
Gasoline- 34.2 MJ/L
Diesel- 38.60 MJ/L
BioDiesel- 32.97 MJ/L
Hydrogen- 12 kJ/L
Methanol- 15.912 MJ/L
Ethanol- 21.1 MJ/L
here is an interesting presentation in PDF form that compares several different alternative fuel sources:
http://www1.eere.energy.gov/hydrogenandfuelcells/pdfs/bulk_hydrogen_stor_pres_sandia.pdf
One of my profs at colledge (fuel and energy are not his field) recently pointed out that if we converted every inch of unused ground here in the US to the growth of corn, and used all that corn just to make alchahaul, we could produce enough to supply approximately 1/10 of our consumption.
Rather daunting, but this fellow may not be completely reliable for information on this topic (I think he may b a bit of a conspiracy theorist).
Maybe not exactly the right numbers Lurch, but the fact that we don't have nearly enough arable land to develop an alcohol economy based upon traditional methods are well documented, i.e. it's a valid point.
I too accept that all the world's fuel needs cannot be run on alcohol as there is not enough land space. However, it is not entirely impossible to create one. Would it be cheaper to run?
Milage apart, it would also have a lower price than the present price of petrol. In the race for hybrid cars, why is this option not being utilised?
Alcohol cars are not being pursued as aggressively as other options for the exact reasons above, i.e. we already told you. The possibility of it being cheaper is useless, because we wouldn't be able to make enough alcohol in the first place.
Here in CA alcohol cars would receive tickets for driving drunk.
:smile: :smile:
Banerjeerupak, conventional fuels are not inherently expensive. Taxation and politics have more to do with the price of petrol than well to wheels production costs.
So that's why my 100 mpg carbeurator never got...
Never mind...
got your point... but do tell me about the milage that such a fuel would be able to give in a normal engine. that's the reason i got onto this
Refer to this, particularly page 2
http://www.eere.energy.gov/afdc/pdfs/fueltable.pdf
Comparison of gasoline, diesel, methanol, ethanol and other fuels.
Methyl Tert Butyl Ether would be great energywise, but it is carcinogenic and has contaminated water supplies in areas where it is used as a gasoline additive.
Methonal is toxic and fatal if a sufficient amount is ingested.
I forgot all about this post.
Thanks for the linK Darren.
Hydrogen
The future is and should be hydrogen from renewable sources. If u take a small part of the american desert (small by comparison) and build electrical/thermal power plants u would be able to generate enough electricity for homes and enough electricity to produce hydrogen at a value not so much more expensive than oil. If you use all the american desert i think u can cover the whole world. I wrote my senior year book in mechanical engineering about this subject, and did an all out engineering and cost research. The infrastructure is present for hydrogen, because all u need to do is modify existing fuel stations. so its not about the price or infrastructure, its about actually doing it.
AIAA Daily Launch said:
In a front-page story, the Wall Street Journal (5/21, A1, Dreazen, subscription required) reports, "With fuel prices soaring, the U.S. military, the country's largest single consumer of oil, is turning into an alternative-fuels pioneer." The Journal notes, "The U.S. military consumes 340,000 barrels of oil a day," and "[t]he Defense Department's overall energy bill was $13.6 billion in 2006, the latest figure available -- almost 25 percent higher than the year before." There is also concern that the military's "dependence on oil represents a strategic threat." The result of these factors is tests such as the recent flight of "a B-1 stealth bomber code-named Dark 33," which "confirm[ed] for the first time that a plane could break the sound barrier using synthetic jet fuel."
Synthetic fuels research picked up during the 70's and 80's during the previous fuel crisis. The research level rises and falls with the price and supply of oil and alternatives.
  • · Replies 131 ·
11K
  • · Replies 24 ·
  • · Replies 39 ·
  • · Replies 22 ·
  • · Replies 16 ·
