Calculating Receiver's Path and Speed to Catch Thrown Ball
  • Thread starter Thread starter neochris
The problem involves a quarterback throwing a ball at a specified speed and angle, with a receiver positioned a certain distance away. The task is to determine how far the receiver must run and at what speed to catch the ball, assuming no external forces and that the vertical displacement is zero.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the implications of the vertical displacement being zero and how to calculate the time the ball is in the air based on its vertical velocity. There is mention of using distance and velocity formulas to find the distance the ball travels and the receiver's required speed.
Some participants have provided calculations and methods for determining the time the ball is in the air and the distance it travels. There is acknowledgment of the need to double-check the calculations presented. The discussion appears to be progressing with helpful insights shared.
Assumptions include that the receiver starts running at the same time the ball is thrown and that the vertical displacement of the ball is zero. The problem is framed within the constraints of a physics homework context.
neochris
A quarter back throws a ball 18 m/s at an angle of 35 degrees above the horizontal. Standing 18 m away is the receiver. How far does the receiver have to go and at what speed must he travel to catch the ball.
Assume that the delta Y is 0.
Assume that the receiver leaves the same time the ball is thrown.
No outside forces.
What do u infer from \delta y =0
Can u calculate the distance covered by the ball
Neat question.
First you have to find the time the ball spends in the air based on the Y velocity. Rearrange the distance formula (d = Vi*t + 1/2*a*t^2) or double the rearranged velocity formula (Vf = Vi + at). I personally prefer the velocity one since quadratics make things more difficult.
[tex]t = 2(\frac{V_f - V_i}{a})[/tex]
In this case, t is the total time in the air, Vf is 0, Vi is the initial velocity of the ball and a is gravity (remember that gravity is negative). Expanded looks like this
[tex]t = 2(\frac{0 - 18sin(35)}{-9.81})[/tex]
t = 2.1049
Now find the distance traveled with d = vt.
[tex]d = (18cos(35))(2.1049)[/tex]
d = 31.036
Now as for how far the guy has to run. He's already 18m away but he has to be 31.036m; he has to run 13.036m and he has to be there in 2.1049s. Just divide to get his speed.
Double check my numbers though.
Thanks that helps a lot.
  • · Replies 38 ·
