Why is it hard to walk without bending your knees?
  • Thread starter Thread starter celect
    Bending Hard
Walking without bending the knees is challenging due to the concept of rotational inertia, which is the resistance of an object to changes in its state of rotation. The human body, particularly the upper body, has significant mass that contributes to high rotational inertia. This resistance makes it difficult to maintain straight legs while walking. Bending the knees reduces this inertia, facilitating smoother and more coordinated movement.
  • Understanding of rotational inertia and its effects on motion
  • Basic knowledge of human biomechanics
  • Familiarity with concepts of mass distribution
  • Awareness of angular momentum principles
  • Research the principles of rotational inertia in biomechanics
  • Explore the effects of mass distribution on human movement
  • Study angular momentum and its application in sports science
  • Investigate the role of joint flexibility in locomotion
Students of biomechanics, physical therapists, athletes, and anyone interested in understanding the mechanics of human movement.
celect
In the terms of rotational inertia why is it hard to walk without bending your knees?
The greater the bulk of the object mass to its axis the greater its rotational inertia.
how can I relate that to walking without bending knees?
I understand that with rotational inertia an object resist
any change in its state of rotation. I just down know how to
phrase this question
The harder something is to get spinning, the more rotational inertia it has. If you want to get something spinning, does moving it closer to the axis of rotation make it easier or harder?
Let's take an example. Say you are standing with a 10 pound dumbell in each hand. Which way makes it easier for you to get yourself spinning (around a vertical axis): (1) holding your arms straight out and the weights as far from your body as possible?, or (2) holding your arms bent, the weights as close to your body as possible? The configuration that makes it easier to turn is the one with the smaller rotational inertia. Got it?
So... what are you doing when you walk? You are rotating your leg about your hips, right? What does bending your knee do?
It is hard to walk without bending your knees because the human body has a significant amount of mass and bulk, particularly in the upper body, which creates a high rotational inertia. This means that when we walk, our body naturally resists any changes in its state of rotation, making it difficult to keep our legs straight and move in a smooth, coordinated manner. Bending our knees helps to reduce the rotational inertia and allows for easier movement while walking.
  • · Replies 30 ·
  • · Replies 19 ·
11K
  • · Replies 21 ·
