Uncovering the Wave-Particle Duality of Light: A Comprehensive Theory Explained
  • Context: Graduate
  • Thread starter Thread starter Owen
    Light Theory
The discussion revolves around the wave-particle duality of light, exploring the nature of photons and their behavior in various contexts, including the photoelectric effect and the double-slit experiment. Participants examine theoretical models, physical properties, and implications of light as both a particle and a wave.
  • Some participants propose that light is fundamentally a particle, specifically photons, which are emitted by electrons during energy level transitions in atoms.
  • Others argue that photons must have mass due to their momentum and their ability to cause ionization in the photoelectric effect, questioning how massless particles could achieve such effects.
  • A later reply challenges the notion that photons have mass, suggesting that momentum can exist without mass and that light energy differs from kinetic energy.
  • Some participants express confusion regarding the behavior of photons in the double-slit experiment, questioning how out-of-phase photons can produce interference patterns when arriving one at a time.
  • There is a discussion about the nature of sound waves and their mass, with some asserting that sound has mass while others clarify that sound waves themselves do not possess mass.
  • Questions arise about the medium through which light propagates if it behaves as a wave, contrasting it with sound waves that require a medium for transmission.
Participants express a range of views on the nature of light, with no consensus reached on whether photons have mass or how they should be modeled. The discussion remains unresolved with competing theories and interpretations presented.
Some claims about the properties of photons and their behavior in experiments rely on specific assumptions that are not universally accepted. The discussion includes various interpretations of energy and mass that may depend on differing definitions and conceptual frameworks.
Owen
Light, what is it? the most up to date theories I have read claim that it is both a particle and a wave (wave/particle duality). How can something that obviously has a physical existence be two things? I agree that in certain situation light behaves as a photon and in others as an EM wave but why is there not one model of light that can predict both of these? I propose that they is. Since my theories are usually overly complex i'll summerise it here and if anyone is interested i can elaborate further.
Light IS a particle, infact not just light but all electromagnetic radiation consists of photons. These photons are emitted by electrons when they change energy levels within an atom. For a photon to exist it must have mass (no matter how small) and it is generally accepted that photons have no charge. However, if a photon has no net charge but does have a positive and negative side to it, as the photon departs from the electron its possitive side would remain pointing towards the negative electron (only for a very short period of time). This would cause the photon to spin. The spin would be proportional to the magnitude of its charges which would be proportional to its mass. The frequency of a photon is also proportional to its mass so provided the proportionalities are the same (which can be shown if some basic assumptions are made) then the angular frequency of the photon is equal to its observed EM frequency. This can be used to explain how photons can be observed to behave like waves. it will take a particular distance for a photon to rotate through 360* (this is its wave length). If a pair of photons arrive at an atom facing opposite directions (ie, out of phase) then the one with possitive facing forewards would hit an electron, and the negative one would hit the nucleas, the effect of this is that the charge between the electron and nucleas is unchanged and therefor the electrons energy is unchanged and so no photon is re-emmited, this is observed as deconstructive interference.
Started as a summary but went into a bit more detail (appologises for the tedium). Personally I can't see anything wrong with my theory, but I'm obviously biased so I would appreciate critisism (and praise if any is deserved) from anyone who is interested.
Science news on Phys.org
How would this explain the twin slit experiment, where the photons arrive one at a time?
It was my belief that photons arriving at one point from each slit arrived together. If light is thought of as a wave then the out of phase points on the wave must arrive together, so surely the photons must also
The statement that photons have mass needs to be substantiated with physical evidence.
Photons have momentum so how can they not have mass? ofcourse they don't have much mass but they must have some. I always thought that the photoelectric effect was proof enough that photons had mass, how can something that is massless knock an electron out of its orbit? Also, when photons are absorbed and re-emitted inside dense mediums surely a massless particle could travel in the gaps between electrons and the nucleas (atoms being mostly made up of nothing), but if they have mass then they can have a force applied to them by either the electron or nucleas in order to change their path
Uh... I think you have the wrong conception of such ionisation here. It is not a real billiard ball style collision. And things with momentum can have no mass.
But then, a great majority of other photons must also have arrived in no pair at all. If we are to presume these all register as hits, this would not reproduce the interference pattern we see. There would simply be no empty patches.
Thats a very common misunderstanding about how light works. Simply put, light energy isn't the same as kinetic energy.
Consider this:
Does sound have energy?
Does sound have mass?
Russ,
Does the photon have potential energy?
Is energy conserved when the small amount of energy it takes to make a sound moves from mouth to rarefactions and condensations?
I had read that 10,000,000 people's voices together would equal the energy running a flashlight.
LPF
I would say that if light is thought of as a particle it can not be associated with sound. However sound does have mass, just because that mass isn't moving in a straight line doesn't mean it has none, if you measure a sound wave impacting on a surface then surely there will be a certain mass of air which is hitting the surace?
Light cannot behave like sound because sound propogates through a sea of atoms in the form of compressions and rarefactions, if light is a form of wave what does it propagate through?
Potential energy is mass times height. So, no.
I'm not exactly sure what you mean here - but since air is not an ideal gas, there are energy losses in the transmission of sound.
Air has mass, but a sound wave itself does not - over what volume (size) would you measure the mass of the "sound"? A guitar string transmits sound to the air (and to the pickup) - is the mass of the guitar string the mass of the sound? Would a loud sound have more mass than a soft one? Since the air that strikes your eardrums isn't the same air that left the surface of a drum (for example), which is the one you measure the "mass" from?
Similarly, light is not a particle and does not have mass. Light is modeled as a wave/particle entity, but that's just a model.
What i mean is not that a sound wave has mass, but sound that hits a surface does. For a constant frequency of sound there will be a particular kinetic energy transferred into a surface by a sound wave, this is due to the mass of the atom and its speed at the time of impact. Sound does not have mass its own mass, but at the point of impact it does have kinetic energy which means it must have mass (possibly proportional to the frontal area of the wave)
If light it to be modeled as a wave what does it travel through? Sound waves rely on the transmittion of kinetic energy from moelcule to molecule in order to advance, how do light waves advance?
Owen,
I hope you don't mind me inserting a qustion or two, they are related to your thread. Maybe the answers can help both of us.
A sound wave is a pulse through a medium, like an ocean wave. If you were to put red dye in the water, it would bob up and down, but not be carried by wave as it went by. A sound wave uses the mass of air as a medium, but they stay stationary (air molecules). The vibration you feel from sound (like speaker box) is resonance from the air vibration rate and the woods' (or?) rate (density state change) as the pulse moves through. I don't know if this is exactly correct. I had never thought of a mass and sound relationship.
Russ,
I understand the lifting of an object with mass to a height gives it potential energy, maybe my misunderstanding is in the photoelectric effect? Does light transfer energy to the electron in this?
Or maybe from infrared portion of wave causing heat - is that a kind of energy?
LPF
Yes and yes. Photons give energy when absorbed and infrared light is radiated thermal energy - and that's the point. Energy in photons is not kinetic or potential beccause it has no mass. But it is energy nonetheless.
You are correct. Sound waves travel through air which has mass, so there is kinetic energy transferred that way. But the mass is there before the sound goes through and stays after the sound - its not a part of the sound.
Light is modeled as a wave, but the medium is where the analogy with sound breaks down. Light doesn't travel over a medium. Essentially it is its own medium.
Russ,
So the third kind of energy is just "regular"?
Is this from Classic, Quantum, and Relativity viewpoints?
(I'm trying to use the right energy with the right equations)
LPF
If light is its own medium then surely the idea of emission and absorption of photons is all wrong. Surely this is going back to the idea of an ether, or in this case a mass of photons floating about in space. When an atom loses energy it sends a wave through these photons, at the point where this wave is detected it will be seen to have both wave like properties and kinetic energy. This view does seem quite plausible but it was my understanding that the idea of an ether is almost universally seen as incorrect, any thoughts?
http://www.energizingbuddies.cc/types.html might be helpful. Mechanical energy and light energy, aka "radiant" or "electromagnetic" energy are only two of 6 types of energy.
And be very careful that you don't apply the wrong equation to the wrong type of energy. For example, people have used the mechanical energy equations to calculate that light should have mass. But you can't do that because mechanical energy equations only work for mechanical energy.
If light is its own medium then surely the idea of emission and absorption of photons is all wrong. Surely this is going back to the idea of an ether, or in this case a mass of photons floating about in space. When an atom loses energy it sends a wave through these photons, at the point where this wave is detected it will be seen to have both wave like properties and kinetic energy. This view does seem quite plausible but it was my understanding that the idea of an ether is almost universally seen as incorrect, any thoughts? [bold added]
Ether is now seen as unnecessary, but the particle/wave duality doesn't depend on it anyway. Also, the photon is the "particle" of light itself, not a medium for carrying it.
This theory is getting more complex than I intended, rather than looking for a model for light why shouldn't we try and look for what light is. What I mean is, light does behave like both a particle and a wave, but surely it has to be something and can't be both. A spring can behave like a wave (when oscilating under simple harmonic motion) but although in that situation it can be modeled as a wave it is still a spring. Just because light behaves like a wave doesn't mean it is, and treating it as a wave doesn't get any closer to finding out what it really is
Au contraire. Since it behaves like a wave in many cases, it must be treated like one in appropriate situations, otherwise we have no way to predict how devices that depend on its wave properties will work. How, for example, are you going to get new eyeglasses made if you're not allowed to model light as a wave?
What a great disucssion... I can't help adding my opinion..
Light THeory, like all things, is being explained by humans.
This means we are forced to try to use existing familiar concepts.
Unfortunately, humans arent very good at understanding things that don't have an easy analogy with some other sensory or mental experience. The closest experience we have for light is either particle or wave, our tendency is to want it(model) fit neatly into one theory/analogy.
I think the argument of "what is light (P or W) ?" is mostly irrelevant. Whats important is that we use consistent and agreed ways of expressing its ACTUAL behaviour - particle or wave..
When trying to <i>explain</i> light, I personally tend to favour the wave model... because I feel that expressing the fact that light energy is probablistically distributed in space is more important, and more accurate for most technically precise applications.
I suspect that its probably easier to consequently treat electrons (and all sub-atomic particles) in the application as waves too.
The same can go for the debate over whether it has mass.
You better be able to explain the construction of the universe.
We should use the physics as a tool before explaining the physics, and we should explain the physics before using it as a weapon.
So were are we know?
Photons have never been experimentally found to have any mass. You said later they had momentum, which is true but they don't have any rest mass. The reason they have a momentum is because they have a mass equivalent, E = mc^2 and what people have confuse is that mass is energy and energy is mass.
What you're talking about sounds like Van Der Waal's forces within a photon. For such a force to exist there would need to be sub-particles within the photon that were charged. Not only this, but the electrostatic interaction would not only generate angular momentum but more significantly a drag force on the photon. If this happened the photon would decelerate (since you propose it has a rest mass) and this would in turn mean the speed of light was variable. However, the speed of light has never been measured to be different to 3x10^8 ms^-1 despite hundreds of experiments on it.
You have to give some kind of mathematical proof of this really.
Also - As someone mentioned earlier on, this doesn't explain photons being fired one at a time.
I think the argument of "what is light (P or W) ?" is mostly irrelevant. Whats important is that we use consistent and agreed ways of expressing its ACTUAL behaviour - particle or wave...
Well put. Welcome to the forum.
You too, natski.
Photons cannot have mass. They would infringe relativity rules (a mass cannot travel at light speed).
In effect their behaviour is such as they have mass (sometimes).
But what do you think if mass is the only exsisting thing and light (also photons) is non-existing?
From this point light phenomena could be only a result of some rules of behaviour of mass.
In other words mass is acting as a vacuum-attractor and light is the opposite behaviour (do not think of anti-matter please).
So, where dark mass is, there gravity is at its maximum. Where a ligthened mass is, there gravity is "masked". The effect of photons "pushing" a reflecting flag is easily replaced by the unbalanced gravity that is more influenced from the "dark side" of the flag and causes it to be more attracted towards that side.
A wave in the ether seems to have mass.
It appears to have a lower density respectivelly higher density than the higgsparticles itself why it gets pushed away as an oddity in space. Just like mass.
The change the electromagnetic wave causes has mass, the mass that is caused is at rest.
Imagine a hole in two strings created by two waves moving out through the strings; the hole's got a mass, but the strings don't.
Do you think that is there anything that everlasts in aethernum?
How is it possible that ether (what is it in effect and which is its relation with matter?) changes its density without proper mass?
I think that a fish in water couldn't say anything about the medium in which he is immerged... but he could perceive something dense that is around him.
Ether is a mental construction but doesn't explain the nature of space-time. It doesn't unify the fundamental forces.
How is it possible that energy can travel trough air like a wave?
Maybe the etherparticles are held together by forces also, just like mass
  • · Replies 34 ·
11K
  • · Replies 36 ·
10K
  • · Replies 22 ·
  • · Replies 20 ·
