Proofs: If a|b then -a|b, a|-b, -a|-ab
  • Context: Undergrad
  • Thread starter Thread starter wubie
    Proofs
The discussion revolves around proving the implications of divisibility in integers, specifically the statements: if \( a|b \), then \( -a|b \), \( a|-b \), and \( -a|-ab \). Participants explore the definitions and reasoning behind these statements, focusing on elementary proofs and the logical steps involved.
  • Some participants propose that if \( a|b \), then \( b = ac \) for some integer \( c \), leading to the conclusion that \( -a|b \) since \( b = -a(-c) \).
  • Others suggest that the proof can be simplified by stating that since \( a|b \), then \( b = ac \) implies \( -b = -ac \), thus \( -a|-b \).
  • One participant expresses uncertainty about proving \( -a|-b \) and attempts to clarify their reasoning by stating that if \( b = ac \), then \( -b = -a c \) shows \( -a|-b \).
  • Another participant points out that to prove \( -a|-ab \), one needs to find an integer \( q \) such that \( -aq = -ab \), suggesting that \( q \) could be \( b \).
  • There is a discussion about the clarity and strength of the proofs, with some participants feeling that their initial attempts seem weak or unclear.
Participants generally agree on the definitions and initial steps for the proofs, but there is no consensus on the strength or clarity of the arguments presented, particularly regarding the third statement and the implications of \( -a|-ab \). The discussion remains unresolved with multiple viewpoints on the adequacy of the proofs.
Some participants express uncertainty about the logical flow of their proofs and the definitions used, indicating potential limitations in their reasoning or assumptions that may not be fully articulated.
wubie
Hello,
First I will post the question that I am working on.
Prove: If a|b, then -a|b, a|-b, and -a|-ab.
I am not good at proofs (even elementry proofs such as these ones). I was wondering if someone could take a look at my work and perhaps confirm whether my proofs are adequate and/or make some suggestions.
First I will start off with a basic definition of a divisor:
An integer, a, not equal to zero, is called a divisor of an integer b if there exists an integer c such the b = a c.
i) If a|b then -a|b.
Assume a|b. Then b = a c for some integer c by def.
Let c = -k where -1, k are integers. Then
b = a (-k) = - a k.
Since k is an integer, then by def., if a|b then b = -a k.
Similarly,
ii) If a|b then a|-b.
b = a c = a -k = -a k = -(a k)
-b = --(a k)
-b = a k
Once again since k is an integer, then by def., if a|b then -b = a k.
Also
iii) If a|b then -a|-b.
I am sort of stuck on this one. I am not yet sure how to show
If a|b then -a|-b.
I thought
b = a c,
-b = -a c
By definition, -a|-b if -b = -a c for some integer c. Since c is an integer, then by def. if a|b then -a|-b.
Part iii) seems pretty weak to me. In fact all look pretty weak now.
Any help/insights are appreciated.
Thankyou.
Originally posted by wubie
Hello,
b = a (-k) = - a k.
this is fine but i would adjust it a bit:
since a|b, b=ac for some c∈Z. then b=(-a)(-c), implying that -a|b as -c∈Z.
(ie there is no need for the k)
[/b]
If a|b then -a|-b.
I thought
b = a c,
-b = -a c
Thankyou. [/B]
that's fine i think. here's how i would phrase it. since a|b, b=ac for some c∈Z. then -b=-ac, which implies that -a|-b.
[/b]if If a|b then -a|-ab.[/b]
you want to find an integer q such that -aq=-ab. what might q be?
Well, by cancellation I would say that q - b. But I don't understand your point.
Let me try this again.
iii)
Prove if a|b then -a|-b.
Assume
a|b.
Then by definition
b = a c for some integer c.
Let
Then by definition
-a|-b.
Therefore
If a|b then -a|-b.
How would that be?
It seems a little stronger than what I had. But it feels like I am missing something inbetween.
that seems fine except for the word "let."
q would be b.
-ab=-ab implies that -a|-ab.
That was a typo on my part. I meant q = b. 8)
I am not sure I am getting this though.
If you have
-a q = -ab
for some q in this case, I could then say
-a|-ab by definition.
I can see it better in the other direction:
Say -a|g.
Let g = -ab. Then
-a|-ab. So by definition
-ab = -a q from some q which is an element of the integers.
If -ab = -aq, then b =q by cancellation.
I feel like I am trying to run through a brick wall while the way through the brick wall is a door just a couple of feet to one side.
8(
  • · Replies 23 ·
  • · Replies 40 ·
