Prooving Area of Circle Equation
  • Thread starter Thread starter rhyso88
    Area Circle
The discussion revolves around proving the area of a quarter circle using integration techniques, specifically through the integral of a quarter circle's equation. The original poster presents their work on evaluating the integral of the function sqrt(25-x^2) and aims to demonstrate that the result aligns with the formula for the area of a circle, pi*r^2, where r is the radius.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the substitution method for evaluating the integral, with some questioning the variable used in the substitution (u vs. θ). The original poster expresses confusion about substituting back into the integral after performing the substitution, particularly regarding the limits of integration.
There is an ongoing exploration of the substitution method and its implications for the limits of integration. Some participants provide clarifications on the substitution process and the relationship between the integral and the area of a circle, while the original poster acknowledges a misunderstanding regarding the limits of integration.
The problem requires the use of specific substitution techniques as stipulated in the question, and there is a noted confusion about whether the area being calculated pertains to a quarter circle or a semi-circle, which affects the limits of integration.
rhyso88
Hi, i am hoping that someone could help me or give me a hint for the follwing question...i will show what I have done so far
The area of a quarter circle given is
Integral sqrt(25-x^2) dx
Use the substitution x = 5 sinu to evaluate this def integral exactly an show that your answer is consistent with area pi*r^2 with radius r
firstly i did dx/du = 5cos u
then i said:
Integral 5sqrt(1-sin^2u).5cosu du
Integral 5cosu.5cosu
Integral 25 cos^2u du
Integral 25(1+cos2u)/2
Integral 25/2 +25cos2u/2
and well the problem i am having is that i don't know how to get the u =5sin u to SUB into the intergal so i can solve it (ie i can SUB u into cos2u...it doesnlt work)
so hopefully someone could point me in a better diretion to solve this??
thanks heaps!
it shouldn't be [tex]x = 5\sin u[/tex], it should be [tex]x = 5\sin \theta[/tex].
And the difference between those two is?
I don't understand what your question is. You seemed to be able to substitute and integrate!
If your question is "How do you know to make that substitution?", it's because of: sin2u+ cos2u= 1 so that
1- sin2 u= cos2u, a "perfect square".
If your question is "how do I do that last integral", [itex]\frac{25}{2}\int 1+ cos(2u) du[/itex], you certainly should know that the integral of 1 du is u and the integral of cos(2u) is (1/2)sin(2u). That integral is
[itex]\frax{25}{2}u+ \frac{1}{2}sin(2u)[/itex]. Since you say you are dealing with a quarter circle and you appear to have set it up with center at (0,0) and radius 5, your original integral is from x= 0 to x= 5. 5 sin u= x= 0 or sin u= 0 when u= 0 and 5 sin u= x= 5, or sin u= 1 when u= [itex]\pi/2[/itex] your limits of integration in the final integral are 0 and [itex]\pi/2[/itex].
sorry
the question is to proove using intergation techniques and this quarter circle as an example, that the area of a quarter circle is 1/4*pi*r^2. Ie intergrate the given integral and compare that to the area of a circle formula and see that they match. However, the question stipulates that you must use the substitution which I outlined...which leads to my prob when i get to the part where you substitute this : x = 5 sin u back into the equation which is meant to be easier to integrate... so i guess you could say
i don't know how to get u =5sin u (the upper limit) to substitute into the integral:
25/2 + 25 (cos 2u)/2 (which is as simplified as i can get the intergal)
thanks for all you responses btw! appreciated
No Its A Half Circle!
SORRY! just rechecked the Q, its a semi circle, not a quarter!
I understand the intergal you did completely, no probs there!
okay here's wat i don't get, how did you change the limits which i had i had, ie 0 and 5 sin u into numbers which I can actaually substitute into the intergal and then solve, it is irrlevant whether a quarter circle or half circle, but i chose quarter circle since the limits 0 and 5 seemed easier.
hang, i think i found my error, the limits therefore should be what you said, i was doing sumthin completely stupid with my limits, i don't know where 5sinu came from as a limit! sorry...THANKU HEAPS FOR YOU HELP!
5 = 5sinu, so sin u = 1.
x^2 + y^2 = r^2, y^2 = sqrt(r^2 - x^2)
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 21 ·
