Making Vector Addition programmeable
The discussion focuses on creating a program for vector addition and subtraction, specifically for handling two or more vectors defined by their magnitude and angle. The user seeks clarity on the mathematical processes required, particularly in converting vectors to components and applying the law of cosines. Key steps include subtracting angles and converting vectors into a usable format for calculations. The conversation emphasizes the need for a structured approach to vector mathematics in programming.
  • Understanding of vector components and their representation
  • Familiarity with trigonometric functions (sine, cosine)
  • Knowledge of the law of cosines
  • Basic programming concepts for implementing mathematical operations
  • Research how to convert vectors to Cartesian coordinates
  • Learn about implementing trigonometric functions in programming languages
  • Study the law of cosines and its application in vector mathematics
  • Explore programming libraries that facilitate vector calculations, such as NumPy for Python
Mathematicians, physics students, software developers, and anyone interested in implementing vector mathematics in programming projects.
KingNothing
Hello...I really want to make a program that can do vector addition and subtraction, given two or more vectors. The problem is, I'm not sure of the math that would be needed to do it. See, I want the person to be able to enter two or more vectors with a magnitude (length) and angle (with 0 degrees being 'up' and 90 degrees being 'right'). I'm struggling a bit with the actual math that needs to be done. I can do it on paper just fine, because the process of taking a bearing of 1125 degrees and making it 45, etc, things of this nature - is logical. But programs don't understand logic. That's where I hit the roadblock.
I don't think you need to know any programming whatsoever to answer this (granted you know the answer)...just be able to say things like:
1. Sbtract angle a from angle b, save to variable a.
etcetera. I'd a little fuzzy on the part of figuring out how to "get two vectors together" to be prepared to use the law of cosines and whatnot to figure the resultant out. Can you help?
Convert each of the vectors to components in some basis, then add the components.
- Warren
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 19 ·
  • · Replies 25 ·
9K
