Find All Solutions of the Congruence
  • Thread starter Thread starter wubie
The discussion focuses on solving the congruence equation 8x congruent to 6 mod 14. The key conclusion is that the two equivalence classes of solutions are [6] and [13]. The process involves using the GCD, which is 2, and applying the Euclidean algorithm to derive the general solution of the associated Diophantine equation. The proper method includes dividing the equation by the GCD initially and recognizing that the problem effectively reduces to mod 7.
  • Understanding of congruence relations in modular arithmetic
  • Familiarity with the Euclidean algorithm for finding GCD
  • Knowledge of Diophantine equations and their solutions
  • Basic algebraic manipulation skills
  • Study the properties of modular arithmetic and congruences
  • Learn how to solve Diophantine equations systematically
  • Explore the application of the Euclidean algorithm in number theory
  • Investigate equivalence classes and their significance in modular systems
Mathematicians, students studying number theory, and anyone interested in solving modular equations and understanding congruences.
wubie
[SOLVED] Find All Solutions of the Congruence
Hi,
I am having lots of trouble understand how to do the following question:
Find all solutions of
I know that the GCD is 2. Therefore there should be two equivalence classes of solutions.
But what is the PROPER way to find them?
I know that they are [6] and [13]. But I only can seem to get [6]. That being said I don't think the process in which I get [6] is the right way to do it either.
How do I find [13]?
I have spend LONG hours looking over my notes, reading the text, trying to understand the theory behind congruence classes. But I still don't understand how I can find all the equivalence classes of solutions. I always just get one. Even though I know there is more than one.
What is the PROPER way to find all classes?
For example, I use the euclidean algor. to get GCD of 2. Then I do the following
2 = 8 - 1*6
2 = 8 - 1*(14 - 1*8)
2 = 8 - 1*14 + 1*8
2 = 2*8 - 1*14.
I then multiply
2 = 2*8 - 1*14
by 3 and get
6 = 6*8 - 6*14.
From the term 6*8 I get the equivalence class of [6].
First of all, am I proceeding in the correct way for finding the equivalence class of [6]?
Secondly, how do I find the equivalence class of [13]?
Any help is appreciated. Thankyou.
Here's how I would do that problem: "8x congruent to 6 mod 14" is the same as saying "8x divided by 14 has a remainder of 6" or "8x minus some multiple of 14 is 6" or "8x- 14n= 6" for some integer n.
Yes, the GCD of those number is 2 so I would divide the entire equation by 2: 4x- 7n= 3. One could notice immediately that "7- 4= 3" so x= -1, n= -1. Or, use Euclid's algorithm: 7 divided by 4 is 1 with remainder 3 which really says 7- 3= 4 again.
The general solution to the Diophantine equation 4x- 7n= 3 is
x= -1+ 7m and n= -1+ 4m (because 4x= -4+ 28m and -7n= 7- 28m so the m terms cancel). When m= 1, x= 6. When m= 2, x= 13. For larger m, we get values larger than 14 so the two "basic" solutions are 6 and 13. All solutions are in those two equivalence classes.
The only difference between what you did and what I did is that I divided the equation by that GCD at the start. The reason you are not getting [13] is that the problem is "really" mod 7 and 6 and 13 are the same mod 7.
Hi there,
First of all, congratulations on solving the congruence and finding one of the equivalence classes [6]! You are definitely on the right track.
To find the other equivalence class [13], we can use the same process you used for finding [6], but with a slight modification. Instead of multiplying the equation 2 = 2*8 - 1*14 by 3, we can multiply it by 4 to get 8 = 4*8 - 2*14. Then, we can add this equation to the original congruence 8x congruent to 6 mod 14 to get:
8x + 8 = 6 + 4*8 - 2*14
Factor out the 8 on the left side and simplify on the right side to get:
8(x+1) = 8
Now, we can see that x = 0 is a solution, and since 8 is relatively prime to 14, we can add multiples of 14 to 0 and still get a solution. Therefore, the other equivalence class is [13], since 0 + 14 = 14 which is equivalent to 0 mod 14.
In summary, the two equivalence classes for this congruence are [6] and [13]. I hope this helps clarify the process for finding all solutions of a congruence. Keep up the good work!
  • · Replies 23 ·
