Understanding Z Transform Convergence and Power Series for Stable Systems
  • Thread starter Thread starter LM741
    Transform
The discussion centers on the relationship between Z transforms and convergence in the context of stable systems. Participants agree that while a Z transform can be computed for a non-convergent expression using power series, this does not yield a closed-form Z transform. The region of convergence (ROC) is crucial; for stability, it must encompass the unit circle. An example provided is the expression z/(z-a), which converges under certain conditions but can still represent an unstable system if the parameter 'a' exceeds unity.
  • Understanding of Z transforms and their applications in control systems.
  • Familiarity with concepts of convergence and stability in signal processing.
  • Knowledge of power series and their role in mathematical analysis.
  • Basic principles of regions of convergence (ROC) in relation to Z transforms.
  • Study the implications of the region of convergence on system stability in Z transforms.
  • Explore the derivation and applications of power series in signal processing.
  • Learn about the criteria for stability in discrete-time systems.
  • Investigate the properties of Z transforms, specifically focusing on closed-form solutions.
Control system engineers, signal processing practitioners, and students studying discrete-time systems who seek to deepen their understanding of Z transforms and stability criteria.
LM741
hi guys.
Just want to clarify something with the z transform and convergence.
Do you guys aggree with this.
If an expression does not converge you CAN STILL find the z transform (using power series) for the system HOWEVER this will not be the closed form z transform.
just wondering - because in any z transform table you are given a region of convergence - but this is for closed form z transforms.
I suppose all systems are stable if they converge.
thanks
sorry - i think my last statement may be a bit to generalized:"I suppose all systems are stable if they converge."
you can get a system that converges but is not necessarily stable. E.g.
z/(z-a) where region of convergence is defined by, mod |z| > |a|
but a can be bigger then unity (which wil make the system unstable) but the system will still converge as long as z > a. Do you guys aggree?
makes sense beacuse i just read somewhere that for a system to be stable , the region of convergence must include the unit circle.
thanks
  • · Replies 22 ·
  • · Replies 40 ·
  • · Replies 18 ·
10K
