Is this a Typo? | Quantity of Heat
  • Thread starter Thread starter sapiental
    Heat
The discussion centers on a physics problem involving the conversion of potential energy into thermal energy. The correct calculation for the heat transfer required to raise the temperature of 0.250 kg of water from 20°C to 90°C is established as Q = (m_water)(c)(dT) = (0.250 kg)(4190 J/kg·K)(70 K) = 73,325 J. The confusion arises from the book incorrectly using 1 kg for the mass of the water instead of the correct 0.250 kg. This error leads to an incorrect calculation of the height h that the block must fall, which should be based on the accurate mass of the water.
  • Understanding of potential energy and thermal energy concepts
  • Familiarity with specific heat capacity calculations
  • Knowledge of basic physics equations involving mass, temperature change, and energy
  • Ability to interpret and analyze physics problems involving multiple components
  • Review the principles of energy conservation in mechanical systems
  • Learn about specific heat capacity and its applications in thermal energy calculations
  • Explore potential energy formulas and their implications in physics problems
  • Practice solving similar physics problems involving heat transfer and energy conversion
Students studying physics, educators teaching thermodynamics, and anyone interested in understanding energy transfer in mechanical systems.
sapiental
This is one of those test your understanding questions out of the book.
What distance would a 1.00kg block have to fall to raise the temperature of .250kg of water from 20C to 90C? Assume that all potential emergy that the block loses as it falls goes into raising the emperature of the water?
(The system: the block is suspended by string through a pully and t attached to a axel. The axel has more thread wrapped around it and is attached to a horizontally rotating paddle inside a glass filled with water. so as the block falls the paddle is doing work on the water resulting in heat transfer Q. this is the most accurate description I can come up with from looking at the picture)This is the answer right out of the book:
The temperature change is T = 70K so the amount of heat is Q = (m_water)(c)(dT) = (1kg)(4190J/kgK)(70K) = 2.93x10^5J If the block falls a distance h, the amount of potential energy lost is m_block(g)(h), so h = Q/(m_block)(h) = (2.93e+10^5J)/(1.00kg)(9.8m/s^2) = 2.99^4 m
Is this a typo? They clearly distinguish m_water and m_block, yet they use 1kg for the mass of the water instead of .250kg. Or am I misunderstanding the question? I get Q = (.250)(c)(dt).
It's clearly a typo. You are right, the mass of the water should be 0.25 kg in the expression.
thanks a lot!
10K
10K
