Problem with Electronic Feedback?
The discussion focuses on the differences between positive and negative feedback in operational amplifiers (op-amps), specifically inverting and non-inverting configurations. It establishes that positive feedback is rarely used in these amplifiers, primarily serving functions in comparators and oscillators. The output voltage behavior is defined: when the non-inverting input exceeds the inverting input, the op-amp saturates to the positive supply voltage, while the opposite condition drives it to the negative rail. The conversation clarifies that the formulas for calculating output voltage remain unchanged regardless of feedback type.
  • Understanding of operational amplifiers (op-amps)
  • Knowledge of feedback mechanisms in electronics
  • Familiarity with voltage output calculations in op-amps
  • Basic concepts of comparators and oscillators
  • Study the role of feedback in operational amplifier circuits
  • Learn about the design and application of comparators in electronics
  • Explore oscillator design using positive feedback techniques
  • Review the mathematical models for op-amp voltage output in various configurations
Electronics students, circuit designers, and engineers interested in understanding operational amplifier feedback mechanisms and their applications in comparators and oscillators.
gunblaze
Hi, i was reading through the topic on analogue electronics. And every single example on my text seems to just be just on the negative feedback on both the inverting and non-inverting input of an op-amp. What i would like to know is what's the difference between positive and negative feedback on an inverting and non-inverting op-amp. Will there be any changes in the formula to find the Voltage ouput of the op-amp?
You can't use positive feedback on inverting and non-inverting amplifiers. Positive feedback is hardly ever used, but the most common use of it would be for a comparator. When the non-inverting input is at a higher voltage than the inverting input, the op amp will be positively saturated and put out the positive supply voltage. When the non-inverting input drops below the inverting input, the op-amp hits the other (negative) rail. Also, oscillators can be made with positive feedback.
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 59 ·
