Design a Valve for CH4 Gas Stream - 40000 cm3/h
  • Thread starter Thread starter paslar001
    Design Valve
The discussion focuses on designing a valve for a methane (CH4) gas stream with a flow rate of 40,000 cm3/h. Key considerations include determining the appropriate valve size based on flow rate and required pressure drop. Participants emphasize the need for specific details regarding the type of valve to be selected for optimal performance in the application.
  • Understanding of fluid dynamics principles
  • Knowledge of valve sizing calculations
  • Familiarity with pressure drop requirements in gas systems
  • Experience with methane gas properties and handling
  • Research valve sizing methodologies for gas applications
  • Learn about pressure drop calculations for methane gas
  • Explore different types of valves suitable for gas flow control
  • Investigate industry standards for gas valve design and safety
Engineers, designers, and technicians involved in gas system design, particularly those focusing on valve selection and sizing for methane applications.
paslar001
Please help me in this problem...
How to design a valve for gas stream?
To be more spicific let's assume that we have aflow rate of 40000 cm3/h
of CH4 ?
I think that a bit more detail is required. What sort of valve are you in a mind for?
Do you mean size/select? You need flow rate and required pressure drop for size, then application to select it.
  • · Replies 18 ·
13K
  • · Replies 27 ·
  • · Replies 43 ·
